Flash disk RFS format errors, "no segment mapping"
Nick Withers
nick.withers at anu.edu.au
Mon Aug 12 08:37:34 UTC 2013
Hullo all,
I'm trying to get a flash disk (S29GLxxxN) going on ye olde MVME3100
with RFS and'm having troubles...
Here's some console output:
____
Registering /dev/console as minor 0 (==/dev/ttyS0)
init.c:89: init(): Started
fs.c:42: fs_init(): Extracting file-system tar...
fs.c:47: fs_init(): File-system tar extracted
fdisk:read-block:0
fdisk:read-block: no segment mapping: 0
flash.c:203: flash_disk_mount(): Failed to mount flash device "/dev/fdda" to "/etc/daq". Error: "I/O error"
flash.c:155: flash_disk_init(): Failed to mount flash file-system. Error: "I/O error"
fdisk:erase-disk
fdisk: erase-flash:00
fdisk: device-erase: 00
fdisk:recover-block-mappings:00-000
fdisk: seg-read: 00-000: o=00000000 s=2048
fdisk: seg-blank: 00-000: o=00000800 s=512
fdisk: seg-blank: 00-000: o=00000a00 s=512
(snip)
fdisk: seg-blank: 00-003: o=0001fa00 s=512
fdisk: seg-blank: 00-003: o=0001fc00 s=512
fdisk: seg-blank: 00-003: o=0001fe00 s=512
fdisk: queue-seg:00-003: p=252 a=0 u=0 b=0 f=no n=null
rtems-rfs: format: /dev/fdda
rtems-rfs: format: media size = 499712
rtems-rfs: format: media blocks = 976
rtems-rfs: format: media block size = 512
rtems-rfs: format: size = 499712
rtems-rfs: format: blocks = 976
rtems-rfs: format: block size = 512
rtems-rfs: format: bits per block = 4096
rtems-rfs: format: inode size = 56
rtems-rfs: format: inodes = 81 (1.0%)
rtems-rfs: format: groups = 1
rtems-rfs: format: group blocks = 4096
rtems-rfs: format: group inodes = 81
rtems-rfs: format: group 0: base = 1, size = 975, blocksfdisk:read-block:1
fdisk:read-block: no segment mapping: 1
, inodesfdisk:read-block:2
fdisk:read-block: no segment mapping: 2
fdisk:write-block:0
fdisk: write:0=>00-000: queue check: ----
fdisk: write:0=>00-000-000: write: p=252 a=0 u=0 b=0 n=null: f=fffe c=f0b7 b=0
fdisk: seg-write: 00-000: o=00000800 s=512
fdisk:write-block:00-000-000: write page failed: I/O error (5)
fdisk: queue-seg:00-000: p=252 a=0 u=0 b=0 f=FAILED n=null
fdisk:read-block:0
fdisk: read:0=>00-000-000: p=252 a=0 u=0 b=0 n=null: f=fffe c=f0b7 b=0
fdisk: seg-read: 00-000: o=00000800 s=512
fdisk:error:read-block: crc failure: 0: buffer:5bcd page:f0b7
rtems-rfs: format: file system open failed: 5: I/O error
rtems-rfs: format: writing root dir failed: 5: I/O error
flash.c:137: flash_disk_format(): Failed to format flash file-system. Error: "I/O error"
____
The "no segment mapping" bit seems to suggest I've stuffed up with the
initialisation structures...? I *think* I'm defining 4 segments. Here're
(hopefully!) the pertinent bits:
____
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
#define FLASH_DISK_DRIVER { \
.initialization_entry = rtems_fdisk_initialize, \
.open_entry = rtems_blkdev_generic_open, \
.close_entry = rtems_blkdev_generic_close, \
.read_entry = rtems_blkdev_generic_read, \
.write_entry = rtems_blkdev_generic_write, \
.control_entry = rtems_blkdev_generic_ioctl \
#define CONFIGURE_APPLICATION_EXTRA_DRIVERS FLASH_DISK_DRIVER
#define CONFIGURE_FILESYSTEM_RFS
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
#include <rtems/flashdisk.h>
#include <rtems/libio.h>
#include <rtems/rtems-rfs.h>
#include <rtems/rtems-rfs-format.h>
#include <bsp/flashPgm.h>
#include <libchip/am29lv160.h>
uint32_t rtems_am29lv160_configuration_size = 1;
const rtems_am29lv160_config rtems_am29lv160_configuration[] =
.bus_8bit = 0,
//! \todo I believe this can change between MVME3100 boards. Read the configuration out of the VPD EEPROM at run-time?
.base = (void *) 0xFC000000 // Obtained from MOTLoad, using the "flashShow" command
static const rtems_fdisk_segment_desc flash_disk_segment_desc =
.count = 4, // "Number of segments of this type in a row"
.segment = 0, // "The base segment number"
.offset = 0, // "Address offset of base segment in device"
.size = 128 * 1024 // "Size of [each of count] segment[s] in bytes" - hardware dependent?
static const rtems_fdisk_device_desc flash_disk_device =
.segment_count = 1,
.segments = &flash_disk_segment_desc,
.flash_ops = &rtems_am29lv160_handlers
uint32_t rtems_flashdisk_configuration_size = 1;
const rtems_flashdisk_config rtems_flashdisk_configuration[] =
.block_size = 512,
.device_count = 1,
.devices = &flash_disk_device,
// .flags = RTEMS_FDISK_CHECK_PAGES | RTEMS_FDISK_BLANK_CHECK_BEFORE_WRITE,
.flags = RTEMS_FDISK_CHECK_PAGES,
.unavail_blocks = 32, // Are we marking the first segment as unavailable so it can be used for compaction?
.compact_segs = 2,
.avail_compact_segs = 1,
.info_level = 3
static int flash_disk_format(const char *device)
rtems_rfs_format_config config;
int device_fd;
BSP_flashWriteEnable(0);
if ((device_fd = open(device, O_WRONLY, 0))
rtems_error(0, "%s:%u: %s(): Failed to open flash device \"%s\". Error: \"%s\"", __FILE__, __LINE__, __func__, device, strerror(errno));
return (-1);
if (ioctl(device_fd, RTEMS_FDISK_IOCTL_ERASE_DISK) == -1)
rtems_error(0, "%s:%u: %s(): Failed to erase flash device \"%s\". Error: \"%s\"", __FILE__, __LINE__, __func__, device, strerror(errno));
return (-1);
memset(&config, 0, sizeof (rtems_rfs_format_config));
config.verbose = true;
if (rtems_rfs_format(device, &config) != 0)
BSP_flashWriteDisable(0);
rtems_error(0, "%s:%u: %s(): Failed to format flash file-system. Error: \"%s\"", __FILE__, __LINE__, __func__, strerror(errno));
return (-1);
return (0);
____
I've noticed that there's a
c/src/lib/libbsp/powerpc/shared/flash/spansionFlash.c, but that looks
like it's for flash programming? Perhaps this chip isn't supported for
flashdisk usage?
Nick Withers
Embedded Systems Programmer
Room 2.26, Building 57
Department of Nuclear Physics
Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
eMail: nick.withers at anu.edu.au
Phone: +61 2 6125 2091
Mobile: +61 414 397 446
