Flash disk RFS format errors, "no segment mapping"
Matthew J Fletcher
amimjf at gmail.com
Tue Aug 20 12:31:57 UTC 2013
Nick,
I am going to have to investigate a very similar issue on my board,
although i cant offer any advice beyond 'just debug it' as Chris says, can
you post updates an i will see if i can contribute.
On 20 August 2013 05:23, Chris Johns <chrisj at rtems.org> wrote:
> Nick Withers wrote:
>> On Mon, 2013-08-12 at 18:37 +1000, Nick Withers wrote:
>>> Hullo all,
>>> I'm trying to get a flash disk (S29GLxxxN) going on ye olde MVME3100
>>> with RFS and'm having troubles...
>> FYI: I've reproduced what looks like exactly the same problem on 4.10.2
>> (and 4.11 Git master).
> Thanks for this. It isolates the issue to the flashdisk driver.
>> Does anyone know if some flashdisk parameters are hardware dependent
>> (e.g., block and/or sector size)?
> In theory it should not. It looks from the trace the block size matches
> the media block size.
> Any suggestions appreciated :-)
> Nothing other than debugging. It is what this bug needs to fix it. I will
> not be able to look at it for a while.
> Chris
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130820/f2872fb5/attachment.html>
