Synchronization problem in message queue mechanism
Sebastian Huber
Thu Aug 22 15:37:12 UTC 2013
Hello,
for a test case please have a look at the attached patch. If I run this test
on a simulator I get:
(gdb) b threadqprocesstimeout.c:42 if the_thread_queue == 0
Breakpoint 3 at 0x201da00: file
../../../../../../rtems/c/src/../../cpukit/score/src/threadqprocesstimeout.c,
line 42.
(gdb) r
Starting program:
/scratch/git-rtems-testing/rtems/build-sparc-sis-rtems/sparc-rtems4.11/c/sis/testsuites/sptests/spintrcritical20/spintrcritical20.exe
*** TEST INTERRUPT CRITICAL SECTION 20 ***
Support - rtems_timer_create - creating timer 1
Breakpoint 3, _Thread_queue_Process_timeout (the_thread=0x2046b00) at
../../../../../../rtems/c/src/../../cpukit/score/src/threadqprocesstimeout.c:42
42 if ( the_thread_queue->sync_state !=
THREAD_BLOCKING_OPERATION_SYNCHRONIZED &&
(gdb) p the_thread_queue
$1 = (Thread_queue_Control *) 0x0
So we have a NULL pointer access in _Thread_queue_Process_timeout(). This
destroys the system state.
On real systems the sequence in the test case can happen with nested interrupts
which interrupt the clock tick handler (this is a common setup).
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20130822/745398e6/attachment.bin>
