STM32F4 discovery loading issue.
Karel Gardas
karel.gardas at centrum.cz
Wed Aug 28 17:53:09 UTC 2013
Hello,
I'm trying to use STM32F4 discovery board to run some RTEMS programs,
actually starting with hello.exe but I've found that neither using
OpenOCD 0.7.0 on Windows nor using stlink (HEAD) I've been able to load
the program on the board. Stlink was a little bit clearer here and I've
found that if I change flash address from 0x0 to 0x08000000 my program
loads successfully.
My question then is: if STM32F4 BSP is tested, then how to switch my
STM32F4 discovery board to be able to use RTEMS's tests/samples on it as
it was done on reference/developer platform?
Thanks!
Karel
