STM32F4 discovery loading issue.
Jiri Freyvald jiri.freyvald at gmail.com
Wed Aug 28 21:40:41 UTC 2013
Hi Karel,
it actually works very well (I mean for STM32F4 discovery board) and out
of the box.
I myself use stlink (on linux) for uploading RTEMS binaries with the
same parameters for stlink as for any STM32F4 binary (without RTEMS)
for example:
flash write o-optimize/hello.bin 0x8000000
regards,
Jiri
On 28/08/13 18:53, Karel Gardas wrote:
> Hello,
> I'm trying to use STM32F4 discovery board to run some RTEMS programs,
> actually starting with hello.exe but I've found that neither using
> OpenOCD 0.7.0 on Windows nor using stlink (HEAD) I've been able to
> load the program on the board. Stlink was a little bit clearer here
> and I've found that if I change flash address from 0x0 to 0x08000000
> my program loads successfully.
> My question then is: if STM32F4 BSP is tested, then how to switch my
> STM32F4 discovery board to be able to use RTEMS's tests/samples on it
> as it was done on reference/developer platform?
> Thanks!
> Karel
> rtems-users mailing list
> rtems-users at rtems.org
