Can coexists rtems tasks (Classic API) and posix task??
Joel Sherrill Joel.Sherrill at OARcorp.com
Fri Aug 30 21:06:50 UTC 2013
Gedare is not mistaken. Classic tasks can make POSIX thread calls and vice versa.
Beware the pthreads are defined to exit silently deleting themselves and classic tasks consider this a fatal error.
Gedare Bloom <gedare at rtems.org> wrote:
Also note that you would need to "configure" your application
correctly so that the resources are available to create tasks of both
types, e.g.
#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_MAXIMUM_POSIX_THREADS 3
if you have 2 classic tasks and 3 pthreads.
On Fri, Aug 30, 2013 at 4:22 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Yes. If I'm not mistaken, RTEMS tasks can also make posix calls.
> Posix thread priorities are mapped to the RTEMS internal priority
> range of 0-255 (realistically, 1-254, since 0 and 255 are reserved).
> Note that the pthread priorties are inverted, so a 1 becomes 254, the
> lowest schedulable priority in the system. After the mapping, the
> scheduler sees both types of tasks as the same. You can inspect how
> this is done when a pthread is created in the
> cpukit/posix/src/pthreadcreate.c.
> -Gedare
> On Fri, Aug 30, 2013 at 3:13 PM, Nicolás Alvarez <nicoalar.22 at gmail.com> wrote:
>> Hi all,
>> It is possible to use in one app both kind of task? What is the scheduler
>> behavior?
>> Regards,
>> Ing. Nicolás Alvarez
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
