libi2c: Claiming driver slot failed
芮正新 ruizx at sciyon.com
Mon Aug 5 04:16:27 UTC 2013
Hi Nick,
  rtems_io_register_driver return 5 means RTEMS_TOO_MANY, no major number available.
  Do you change CONFIGURE_MAXIMUM_DRIVERS to a suitable value?
Thanks & Best regards,
Rui Zhengxin
-----邮件原件-----
发件人: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] 代表 Nick Withers
发送时间: 2013年8月5日 星期一 12:02
收件人: rtems-users at rtems.org
主题: libi2c: Claiming driver slot failed
Hi guys,
When I boot an MVME3100 (PowerPC) off the ticker sample application, I get an error message "libi2c: Claiming driver slot failed (rtems status code 5)".
Complete boot log:
____
MVME3100> tftpGet -c150.203.19.231 -s150.203.19.211 -fticker.ralf
Network Loading from: /dev/enet0
Loading File: ticker.ralf
Load Address: 014D3000
Download Buffer Size = 00200000
Client IP Address      = 150.203.19.231
Server IP Address      = 150.203.19.211
Gateway IP Address     = 150.203.19.253
Subnet IP Address Mask = 255.255.255.0
Network File Load in Progress...
Bytes Received =&248432, Bytes Loaded =&248432
Bytes/Second   =&248432, Elapsed Time =1 Second(s)
MVME3100> go
Welcome to rtems-4.10.99.0(PowerPC/Generic (no FPU)/mvme3100)
BSP: mvme3100, CVS Release ($Name$)
CPU 0x8020 - rev 0x20
Additionnal boot options are H
Initial system stack at 3FD88
Software IRQ stack starts at 3FE70 with size 16384 Going to start PCI buses scanning and initialization Board Type: MVME3100-1152 (S/N E01230A)
External (=PCI Bus) Clock Freq   :   66666666 Hz
Core Complex Bus (CCB) Clock Freq:  333333330 Hz
CPU Clock Freq:                     133333332 Hz
Ethernet 0                  00:01:AF:30:54:3D
Ethernet 1                  00:01:AF:30:54:3E
Ethernet 2                  00:01:AF:30:54:3F
Number of PCI buses found is : 2
BUS:SLOT:FUN  VENDOR-DEV_ID: COMMAND STATUS BASE_ADDR0 BASE_ADDR1 IRQ_PIN -> IRQ_LINE
  0:0x00:0    0x1057-0x0008:  0x0006 0x20B0 0x80000000 0x00000000       0 ->   0 (=0x00)
  0:0x11:0    0x10E3-0x0148:  0x0146 0x02B0 0x80100004 0x00000000       1 ->   0 (=0x00)
  0:0x12:0    0x10B5-0x6520:  0x0147 0x02B0 0x00000000 0x00000000       0 ->   0 (=0x00)
  0:0x14:0    0x8086-0x3200:  0x0145 0x02B0 0x00011001 0x00012001       1 ->   2 (=0x02)
Memory:                             268435456 bytes
Cleared PCI errors: pci_stat was 0x20B0
OpenPIC Version 1.2 (1 CPUs and 56 IRQ sources) at 0xE1040000 OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 0 OpenPIC timer frequency is 41666666 Hz MSR is 0x00001000, TCR 0x04000000
Exit from bspstart
Tundra Tsi148 PCI-VME bridge detected at 0x80100000, IRQ 0
Tsi148 Outbound Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0E000000 0xC0000000 A32, SUP, D32, SCT
1:    0x00000000 0x00FF0000 0xCF000000 A24, SUP, D32, SCT
2:    0x00000000 0x00010000 0xCFFF0000 A16, SUP, D32, SCT
7:    0x00000000 0x01000000 0xCE000000 CSR, SUP, D32, SCT
Tsi148 Inbound Ports:
0:    0xC0000000 0x10000000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
vmeTsi148 IRQ manager: looking for registers on VME...
Trying to find CSR on VME...
vmeTsi148 - IRQ manager using VME CSR to flush FIFO
libi2c: Claiming driver slot failed (rtems status code 5) Initializing I2C library failed Registering /dev/console as minor 0 (==/dev/ttyS0)
*** CLOCK TICK TEST ***
____
Anyone have any ideas or suggestions on how to resolve this?
Nick Withers
Embedded Systems Programmer
Room 2.26, Building 57
Department of Nuclear Physics
Research School of Physics and Engineering The Australian National University (CRICOS: 00120C)
eMail: nick.withers at anu.edu.au
Phone: +61 2 6125 2091
Mobile: +61 414 397 446
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
