Re: 答复: SDHC driver of RTEMS
ruizx
ruizx at qq.com
Tue Aug 6 01:34:51 UTC 2013
Sebastian Huber wrote:
> On 2013-08-05 12:51, 芮正新 wrote:
>> Thanks for your reply.
>> Can you give me some advices to resolve my problems?
> I would look at the latest errata documents from Freescale and the
> Linux driver.
> I would also test the driver without a file system. Just use the
> bdbuf (or event the driver IO control) directly. Example:
> http://git.rtems.org/rtems/tree/testsuites/libtests/block16/init.c
This example do not define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS, so BRDA task could not start.
I found that if defined CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS, the problem appeared,
and if not define the macro, there was no problem, but the multi-block command never used, just single block read.
Single block access has slow speed and efficiency.
PS:
Sorry for my bad maillist tool, it took some Chinese characters to mails previous.
I've corrected it and changed my maillist account to the new one.
Best Regards,
Rui Zhengxin
