Issues with compiling RTEMS 4.10.2 with Gaisler drivers 1.2.11 on Ubuntu 13.04
    Chris Johns
    chrisj at rtems.org
    Thu Aug  8 20:13:21 UTC 2013
M.Eng. René Schwarz | German Aerospace Center (DLR) wrote:
> Hi,
> thank you all for your help --- both on and off this mailing list. The
> problem seems to be solved now with the kind help of Sebastian Huber:
> The given '--prefix=...' has to be the same while configuring and
> building binutils and gcc.
> The error is gone now, but I ran into the situation that I am getting
> the following error now after doing a 'make all' for RTEMS:
>      make[2]: Leaving directory
> `/home/rtems/rtems_base/build/arch/sparc-rtems4.10/rtems-4.10.2-gaisler-1.2.11/sparc-rtems4.10/c'
>      Making all in erc32
>      make[2]: Entering directory
> `/home/rtems/rtems_base/build/arch/sparc-rtems4.10/rtems-4.10.2-gaisler-1.2.11/sparc-rtems4.10/c/erc32'
>      make[2]: *** No rule to make target `all'.  Stop.
>      make[1]: *** [all-recursive] Error 1
>      make[1]: Leaving directory
>      make: *** [all-recursive] Error 1
> After checking
> '/home/rtems/rtems_base/build/arch/sparc-rtems4.10/rtems-4.10.2-gaisler-1.2.11/sparc-rtems4.10/c/erc32'
> it turned out that there is no Makefile at all in this folder. Do you
> have an additional hint for me?
What is your RTEMS configure command line ?
