Re: MinGW
williamssimonp at gmail.com
Fri Aug 9 23:03:57 UTC 2013
Well, the Eclipse plugin does work! It took a bit of messing around, but ended up being quite simple, it was down to mis-specifying the msys location. Persuading it to build the ram disk binary image was a bit of a challenge, but we got there. At the moment I am assuming it’s going to work. We’ll find out tomorrow, assuming I can find the UART to USB cable I bought six months ago!
Sent from Windows Mail
Sent: Friday, 9 August 2013 12:37
To: williamssimonp at gmail.com
Cc: rtems-users at rtems.org
I can get my RKI project to build on windows ( from a command prompt , without a mingw or cygwin shell )
If you can build it in a command prompt, it should build in eclipse.
For my windows setup, I have the following lines in the makefile:
## Windows paths
RTEMS_TOOL_BASE=c:\opt\rtems\4.11
RTEMS_BSP_BASE=e:\Projects\rtems\bsps\rtems-4.11
Your project sounds neat, I would love to find out more about your avionics board. Let me know if you make any progress with the I2C on the Raspberry Pi, I was going to tackle that when I get some free time.
Alan
On 8/9/2013 4:08 AM, williamssimonp at gmail.com wrote:
Thanks for that Chris, using this build set gave me working a compiler. I hadn't been able to get RTEMS source Builder to work on Windows, but I didn’t try very hard as your build set removed the need. I built the Raspberry Pi BSP and all appears to be well.
I am trying to get RKI to build, but this is early days. I eventually need to use C++ and I like to use the Eclipse IDE and so I have imported the source into Eclipse with a view to getting the original C code to work, prior to porting it to C++ as a base for my project. I am getting undefined references in the link, but I can sort this out, I just need to find which libraries are missing.
The project I am working on is for a Raspberry Pi based autopilot. I have designed an avionics board containing the sensors. This board will interface to the Pi using I2C. I had made a small and insignificant start to writing the autopilot code, but it was a huge job! Linux is not suitable for this kind of application and so I was going to use my own microkernel. Doing this is insanely complicated however. Using RTEMS will save me a huge amount of time as I can concentrate on writing an autopilot and leave the details of memory management, scheduling, etc. to a proven RTOS. Once the autopilot code is in a suitable form, I will be making it, along with the avionics design, available under GPL. Any RTEMS device drivers that I write for the generic Pi peripherals, I will make available as soon as I am happy they work so that they can be considered for inclusion in the BSP.
Please don’t expect miracles. Although I have a lot of experience with low level programming, most of it was a while ago (early 90’s) and I have not used RTEMS before. Also, this is very much a hobby and I do have a life!
Sent: Thursday, 8 August 2013 02:04
To: rtems-users at rtems.org
Sebastian Huber wrote:
> you can use the RTEMS Source Builder (RSB) for this:
> http://wiki.rtems.org/wiki/index.php/RTEMS_Source_Builder
> I normally build the MinGW tools on Linux.
I just built a new ARM compiler for MinGW using the RSB on FreeBSD using ...
../source-builder/sb-set-builder --host=mingw32 --trace --log=log_arm
--prefix=/opt/rtems/4.11 --no-install --bset-tar-file 4.11/rtems-arm
You can find the tar file with the binaries at ...
http://www.rtems.org/ftp/pub/rtems/people/chrisj/source-builder/4.11/mingw32/
I will add more architectures as they become available. These tools
contain all required patches and should work on RTEMS 4.11 master.
Using autoconf and automake in MSYS may require 'mount c:/opt/rtems/4.11
/opt/rtems/4.11" where "c:/opt/rtems/4.11" is the path to where you
unpacked the tar file. The tool such as arm-rtems4.11-as,
arm-rtems4.11-gcc should be relocatable.
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20130809/14b2fd98/attachment-0001.html>
