Synchronization problem in message queue mechanism
Sebastian Huber
Thu Aug 22 14:52:14 UTC 2013
On 2013-08-22 15:23, Joel Sherrill wrote:
>> If I compare the functions _Event_Timeout() and _Thread_queue_Process_timeout()
>> I am a bit surprised that _Thread_queue_Process_timeout() doesn't use
>> _ISR_Disable/Enable() to protect the access to the_thread_queue->sync_state.
>> On a first glance this looks like a major bug.
> The assumption is that _Thread_queue_Process_timeout() is called from a clock tick
> ISR but thinking that doesn't prevent a nested interrupt from occurring.
> Does this system nest interrupts?
I think the problem occurs in case a nested interrupt hits
_Thread_queue_Process_timeout().
It is quite hard to write a test case for this. You need a thread that obtains
a blocked semaphore with a finite timeout. You need a second task that acts as
a pseudo clock tick, that calls the timeout function after some a varying busy
wait. You need a timer that interrupts the pseudo clock tick task.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
