Fail to build hello.exe sample on NetBSD for BSP MIPS jmr3904.
Mon Aug 26 22:17:41 UTC 2013
Ivan Temp wrote:
>   I am trying to get a RTEMS up for MIPS on a NetBSD host.
Nice.
>   I followed the instructions on building tools from source and finally
> I  was able to compile "f.c" and create object file with:
> VirtualNetBSD# mips-rtems4.11-gcc -v -c f.c
>   I have then tried to build RTEMS for BSP jmr3904 and this is all I can
> get after gmake:
Try adding --enable-posix to the configure command line.
Which thread model is your RTEMS MIPs tool chain built with ?
> quote->>
> gmake[3]: Leaving directory
> `/usr/rtems/archive/b-mips/mips-rtems4.11/c/jmr3904/wrapup'
> Making all in testsuites
> gmake[3]: Entering directory
> `/usr/rtems/archive/b-mips/mips-rtems4.11/c/jmr3904/testsuites'
> Making all in samples
> gmake[4]: Entering directory
> `/usr/rtems/archive/b-mips/mips-rtems4.11/c/jmr3904/testsuites/samples'
> gmake  all-recursive
> gmake[5]: Entering directory
> Making all in hello
> gmake[6]: Entering directory
> `/usr/rtems/archive/b-mips/mips-rtems4.11/c/jmr3904/testsuites/samples/hello'
> mips-rtems4.11-gcc -B../../../../../jmr3904/lib/ -specs bsp_specs
> -qrtems -DHAVE_CONFIG_H -I.
> -I../../../../../../../../rtems/c/src/../../testsuites/samples/hello
> -I..     -march=r3900 -Wa,-xgot -G0 -O2 -g -Wall -Wmissing-prototypes
> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
> init.o -MD -MP -MF .deps/init.Tpo -c -o init.o
> ../../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c
> mv -f .deps/init.Tpo .deps/init.Po
> -qrtems -march=r3900 -Wa,-xgot -G0 -O2 -g -Wall -Wmissing-prototypes
>   -march=r3900 -Wa,-xgot -G0   -o hello.exe init.o
> /usr/rtems/rtems-4.11/lib/gcc/mips-rtems4.11/4.8.1/../../../../mips-rtems4.11/lib/libc.a(lib_a-puts.o):
> In function `_puts_r':
> (.text+0x60): undefined reference to `pthread_setcancelstate'
> (.text+0xac): undefined reference to `pthread_setcancelstate'
> /usr/rtems/rtems-4.11/lib/gcc/mips-rtems4.11/4.8.1/../../../../mips-rtems4.11/lib/libc.a(lib_a-fflush.o):
> In function `_fflush_r':
> (.text+0x308): undefined reference to `pthread_setcancelstate'
> (.text+0x324): undefined reference to `pthread_setcancelstate'
> /usr/rtems/rtems-4.11/lib/gcc/mips-rtems4.11/4.8.1/../../../../mips-rtems4.11/lib/libc.a(lib_a-findfp.o):
> In function `__sfp':
> (.text+0x254): undefined reference to `pthread_setcancelstate'
> /usr/rtems/rtems-4.11/lib/gcc/mips-rtems4.11/4.8.1/../../../../mips-rtems4.11/lib/libc.a(lib_a-findfp.o):(.text+0x2cc):
> more undefined references to `pthread_setcancelstate' follow
> collect2: error: ld returned 1 exit status
> gmake[6]: *** [hello.exe] Error 1
> gmake[6]: Leaving directory
> gmake[5]: *** [all-recursive] Error 1
> gmake[5]: Leaving directory
> gmake[4]: *** [all] Error 2
> gmake[4]: Leaving directory
> gmake[3]: *** [all-recursive] Error 1
> gmake[2]: *** [all-recursive] Error 1
> gmake[2]: Leaving directory
> `/usr/rtems/archive/b-mips/mips-rtems4.11/c/jmr3904'
> gmake[1]: *** [all-recursive] Error 1
> gmake[1]: Leaving directory `/usr/rtems/archive/b-mips/mips-rtems4.11/c'
> gmake: *** [all-recursive] Error 1
> end quote ->>
>   I have not made any update of the toolsuite, just downloaded, patched
> and built.
>   Could you please give me a clue on what I have done wrongly?
>   Regards,
>   Ivan.
> rtems-users mailing list
> rtems-users at rtems.org
