STM32F4 discovery loading issue.
Karel Gardas karel.gardas at centrum.cz
Wed Aug 28 22:05:27 UTC 2013
Hello Emanuel,
your info is very encouraging. I've found in STM32F407VG data sheet a
memory map and for address range 0x0000 0000 - 0x000F FFFF they write:
"Aliased to Flash, system memory or SRAM depending on the BOOT pins"
so perhaps just my boot pins are configured in a different way?
Also, by any chance do you remember if you used USART 3 which is on by
default in stm32f4 BSP to print to DM-STF4BB UART or if you had to
change to USART 6 for this?
Thanks a lot!
Karel
On 08/28/13 11:48 PM, emanuel stiebler wrote:
> On 2013-08-28 11:53, Karel Gardas wrote:
>> Hello,
>> I'm trying to use STM32F4 discovery board to run some RTEMS programs,
>> actually starting with hello.exe but I've found that neither using
>> OpenOCD 0.7.0 on Windows nor using stlink (HEAD) I've been able to load
>> the program on the board. Stlink was a little bit clearer here and I've
>> found that if I change flash address from 0x0 to 0x08000000 my program
>> loads successfully.
>> My question then is: if STM32F4 BSP is tested, then how to switch my
>> STM32F4 discovery board to be able to use RTEMS's tests/samples on it as
>> it was done on reference/developer platform?
> Hello Karel,
> sorry I can't help you much today with it,
> but I didn't run into any problems having RTEMS running on the
> discovery. I did this on win7/64, cygnus and using openocd.
> I also have the additional DM-STF4BB board, where I used the UART from.
> Sorry, I just got a new laptop, and I'm still installing software ...
