RTEMS Filesystem check
Sun Dec 1 00:48:05 UTC 2013
On 11/30/2013 5:55 PM, Wendell Silva wrote:
> Hello,
> I'm testing RTEMS RFS file system using qemu (pc386) and huge virtual
> disk file (10G).
> I've created a rfs partition with 8GB with a block size = 4096, which
> allows for huge single file (~ 21 GiB).
> The test program (adapted from fileio example) uses synchronized cache
> and create large files (~1GiB). After creation, the file is deleted and
> during the deletion I just close the qemu window in order to simulate a
> system crash an assess the impact of such event on the file system
> integrity.
> After repeating this (destructive) test lots of times, I've found that
> rfs survives well, but the free disc space is inconsistent because of
> the non-deleted (marked as free) blocks.
> The question is: is there any program/example on how to "sanitize" an
> RFS filesystem, in order the recover these lost/orphans blocks?
> Something like checkdisk.
> If such code does not exist, can you provide me directions on how to do
> that? I think this could be an interesting contribution.
Chris Johns should comment on this as it is his filesystem. :)
Have you looked at the debugrfs shell command? I don't know what
it can do but may be helpful.  I don't think it can do what you
need based on the manual page.
http://rtems.org/onlinedocs/doc-current/share/rtems/html/shell/File-and-Directory-Commands-debugrfsut-_002d-debug-RFS-file-system.html#File-and-Directory-Commands-debugrfs-_002d-debug-RFS-file-system
Looks like an area needing contributions. Hopefully Chris will
pipe up soon but I think he was traveling.
> --Wendell.
