undefined reference to `pthread_setcancelstate' error while building rtems 4.11 with samples.
Kate Feng
kate007.feng at gmail.com
Sun Dec 1 01:52:14 UTC 2013
On Sat, Nov 30, 2013 at 6:35 PM, Kate Feng <kate007.feng at gmail.com> wrote:
> gmake RTEMS_BSP="mvme5500
I meant to type :
gmake RTEMS_BSP="mvme5500"
or
gmake all
Cheers,
Kate Feng
> I used the following configure options (before 'gmake') for RTEMS 4.10.2
> on Ubuntu 12.04 (precise) 64-bit, and it works well.
> ../rtems-4.10.2/configure -target=powerpc-rtems4.10
> -prefix=/opt/rtems-4.10.2 --enable-cxx --enable-rdbg --disable-tests
> --enable-maintainer-mode --enable-networking --enable-posix --enable-itron
> RTEMS_CFLAGS=-g -enable-rtemsbsp=mvme5500
> You should delete the old build directory, and restart a new build.
> Hope that this helps.
> Cheers,
> Kate Feng
> On Thu, Nov 21, 2013 at 7:41 PM, Nadia Gruman <Nadia.Gruman at pro-dex.com>wrote:
>> Hello,
>> I'm building rtems 4.11 on Ubuntu 12.04 (precise) 64-bit for the powerpc
>> mvme5500. I have built and installed the tools successfully:
>> ls /opt/rtems-4.11/bin/
>> powerpc-rtems4.11-addr2line* powerpc-rtems4.11-gdb*
>> powerpc-rtems4.11-ar* powerpc-rtems4.11-gprof*
>> powerpc-rtems4.11-as* powerpc-rtems4.11-ld*
>> powerpc-rtems4.11-c++* powerpc-rtems4.11-ld.bfd*
>> powerpc-rtems4.11-c++filt* powerpc-rtems4.11-nm*
>> powerpc-rtems4.11-cpp* powerpc-rtems4.11-objcopy*
>> powerpc-rtems4.11-elfedit* powerpc-rtems4.11-objdump*
>> powerpc-rtems4.11-g++* powerpc-rtems4.11-ranlib*
>> powerpc-rtems4.11-gcc* powerpc-rtems4.11-readelf*
>> powerpc-rtems4.11-gcc-4.8.1* powerpc-rtems4.11-run*
>> powerpc-rtems4.11-gcc-ar* powerpc-rtems4.11-size*
>> powerpc-rtems4.11-gcc-nm* powerpc-rtems4.11-strings*
>> powerpc-rtems4.11-gcc-ranlib* powerpc-rtems4.11-strip*
>> powerpc-rtems4.11-gcov*
>> and now building rtems. I got the source from git and did the following:
>> export PATH=/opt/rtems-4.11/bin:$PATH
>> ./bootstrap
>> cd ..
>> mkdir b-sis
>> cd b-sis
>> ../rtems/configure --target=powerpc-rtems4.11 --enable-rtemsbsp=mvme5500 --enable-tests=samples --disable-posix
>> make
>> on make I get the following errors:
>> powerpc-rtems4.11-gcc -B../../../../../mvme5500/lib/ -specs bsp_specs -qrtems -mcpu=7450 -mtune=7450 -Dmpc7455 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -mcpu=7450 -mtune=7450 -Dmpc7455 -o hello.exe init.o
>> /opt/rtems-4.11/lib/gcc/powerpc-rtems4.11/4.8.1/../../../../powerpc-rtems4.11/lib/m7400/libc.a(lib_a-fflush.o): In function `_fflush_r':
>> /home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/fflush.c:229: undefined reference to `pthread_setcancelstate'
>> /home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/fflush.c:231: undefined reference to `pthread_setcancelstate'
>> /opt/rtems-4.11/lib/gcc/powerpc-rtems4.11/4.8.1/../../../../powerpc-rtems4.11/lib/m7400/libc.a(lib_a-findfp.o): In function `__sfp':
>> /home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/findfp.c:111: undefined reference to `pthread_setcancelstate'
>> /home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/findfp.c:135: undefined reference to `pthread_setcancelstate'
>> /home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/findfp.c:124: undefined reference to `pthread_setcancelstate'
>> /opt/rtems-4.11/lib/gcc/powerpc-rtems4.11/4.8.1/../../../../powerpc-rtems4.11/lib/m7400/libc.a(lib_a-fwrite.o):/home/nadgru/tools/b-gcc/powerpc-rtems4.11/m7400/newlib/libc/stdio/../../../../../../gcc-4.8.1/newlib/libc/stdio/fwrite.c:122: more undefined references to `pthread_setcancelstate' follow
>> collect2: error: ld returned 1 exit status
>> make[6]: *** [hello.exe] Error 1
>> make[6]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c/mvme5500/testsuites/samples/hello'
>> make[5]: *** [all-recursive] Error 1
>> make[5]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c/mvme5500/testsuites/samples'
>> make[4]: *** [all] Error 2
>> make[4]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c/mvme5500/testsuites/samples'
>> make[3]: *** [all-recursive] Error 1
>> make[3]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c/mvme5500/testsuites'
>> make[2]: *** [all-recursive] Error 1
>> make[2]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c/mvme5500'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory `/home/nadgru/tools/b-sis/powerpc-rtems4.11/c'
>> make: *** [all-recursive] Error 1
>> nadgru at lx-test:~/tools/b-sis$
>> Has anyone encountered this? I tried adding --enable-posix, but that didn't help.
>> Thank you.
>> Nadia.
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20131130/91c295c4/attachment.html>
