NIOS2 ISR Handler with shadow registers
Sebastian Huber
Tue Dec 3 07:43:52 UTC 2013
Hello Kevin,
we may integrate the BSP next year. Attached is our bspstart.c file.
On 2013-12-02 23:28, Kirspel, Kevin wrote:
> I added the global definition for _Nios2_ISR_Status_interrupts_disabled (except
> I used NIOS2_ISR_STATUS_BITS_EIC_IL instead of INTERRUPT_DISABLE_IL_BITS – I
> assume it’s the highest interrupt level in your BSP). It successfully compiles
> but will crash on startup while spitting out the RTEMS shell hello message. So
> it processes some ISRs successfully but then dies. I’m not sure if there is
> more I need to do in my BSP. I have it working with the below ISR handler but
> it doesn’t do everything that yours did.
There are some initialization steps necessary for shadow registers. You should
run the test sptests/spcontext01.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20131203/48ac93f2/attachment.bin>
