debugging RTEMS on the ZedBoard
Mon Dec 9 14:49:43 UTC 2013
The output is the start of the expected output. Perhaps the UART
buffer is not getting clear before the board gets to the end of the
program and halts? You could try to modify the application to while(1)
instead of returning from Init/main() just to see.
On Mon, Dec 9, 2013 at 4:55 AM, Thijs Witteman <thijswitijs at gmail.com> wrote:
> Hello,
> I'm trying to get a simple hello world program, which came with examples-v2,
> to work on the ZedBoard.
> I followed the getting started guide
> (http://rtems.org/onlinedocs/doc-current/share/rtems/pdf/started.pdf) and I
> build rtems from source.
> Unfortualy this guide doesn't show how to program a target board. Normally I
> program my ZedBoard using the Xilinx Vivado enviroment, so I tried this with
> the .exe/.elf file from my build.
> After loading the file to the processor, it crashes. The light that
> indicates my FPGA is programmed will go off and the message "*** HELþ" is
> shown on the UART, so it looks like the ZedBoard is resetting itself.
> On the internet some people were talking about using a bootloader like
> u-boot, but I think it should be possible to program the board runtime.
> I am wondering if anyone has any tips or ideas on how to solve my problem.
> Thanks,
> Thijs
> rtems-users mailing list
> rtems-users at rtems.org
