PowerPC BSP mvme5500 and hardfloat.
Matt Wette
mwette at alumni.caltech.edu
Thu Dec 12 18:53:57 UTC 2013
On Dec 12, 2013, at 9:18 AM, Till Straumann <strauman at slac.stanford.edu> wrote:
> BTW: I have not, with recent gcc, seen implicit use of the FPU.
> - Till
on ppc stfd = store float double
mwette$ cat isr.c
struct ts { int s, f; };
extern struct ts clktim;
extern volatile int *sec, *frac;
void isr() {
struct ts a, b;
a.s = -1;
do {
b = a;
a.s = *sec;
a.f = *frac;
} while (a.s != b.s);
/* oops move a to clktim */
mwette$ powerpc-rtems4.11-gcc -S isr.c
mwette$ cat isr.s
.file "isr.c"
.section ".text"
.align 2
.globl isr
.type isr, @function
isr:
stwu 1,-32(1)
stw 31,28(1)
mr 31,1
li 9,-1
stw 9,8(31)
.L2:
lfd 0,8(31)
stfd 0,16(31)
lis 9,sec at ha
lwz 9,sec at l(9)
lwz 9,0(9)
stw 9,8(31)
lis 9,frac at ha
lwz 9,frac at l(9)
lwz 9,0(9)
stw 9,12(31)
lwz 10,8(31)
lwz 9,16(31)
cmpw 7,10,9
bne 7,.L2
addi 11,31,32
lwz 31,-4(11)
mr 1,11
blr
.size isr, .-isr
.ident "GCC: (GNU) 4.8.2 20131016 (RTEMS gcc-4.8.2-3.el6/newlib-1.20.0-29.el6)"
URL: <http://lists.rtems.org/pipermail/users/attachments/20131212/db28aef2/attachment.html>
