Limiting program RAM addresses
Joel Sherrill
Joel.Sherrill at OARcorp.com
Mon Dec 2 01:43:44 UTC 2013
Is there a LD linker script "include next" or include file but may not be present?, if so, the generic linker script might be able to include a custom extension.
Random thought and probably not a great one but finding a way to support this use case without duplicating the entire linkcmds set would be good.
--joel
On Dec 1, 2013 7:29 PM, Mohammed Khoory <mkhoory at eiast.ae> wrote:
I see, thanks. This makes sense.
I assume in order to make sure that ramdisk_buffer is located in the memory
region that I need, I would have to modify the linker script. Time to
research that I suppose.
>-----Original Message-----
>From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
>Sent: Friday, November 29, 2013 6:17 PM
>To: Mohammed Khoory
>Cc: rtems-users at rtems.org
>Subject: Re: Limiting program RAM addresses
>This doesn't work, but you can use this:
>static char ramdisk_buffer[12288][512];
>rtems_ramdisk_config rtems_ramdisk_configuration[] = {
> sizeof(ramdisk_buffer[0]),
> sizeof(ramdisk_buffer) / sizeof(ramdisk_buffer[0]),
> &ramdisk_buffer[0][0]
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20131201/3bc86a21/attachment-0001.html>
