Error while building gcc for toolset for RTEMS
    Steven Grunza
    sgrunza at ctdi.com
    Thu Feb  7 14:04:38 UTC 2013
Manish,
I just configured my development machine.  It's running a brand new
install of Ubuntu Quantal, x86_64
I used the Fedora RPM packages and the alien Ubuntu package; the
procedure is mostly documented on
http://www.rtems.org/wiki/index.php/Debian_and_Ubuntu
I had to install two missing packages.  I think one of them was
libcloog-isl and I forget the other.  The build of RTEMS failed when the
necessary libcloog.so was missing and the same for the other package.
Reading the build results and doing some experimentation eventually led
me to what I believe are the correct packages.
Checking my log files it looks like I needed to:
  sudo apt-get install clog-isl
  sudo apt-get install libppl-c4
Unless you're really into building tools, I would suggest you try the
RPM/alien path.
I'm working on ARM these days (I haven't worked on SPARC in years) so
you'll have to figure out the correct file set yourself but basically it
should be
http://www.rtems.org/ftp/pub/rtems/linux/4.11/fedora/18/x86_64/:
                The *auto*.rpm
                The *common*.rpm
                The *sparc*.rpm  (this gets both SPARC and SPARC64, not
sure which you need)
For source code I used GIT to grab a copy
Steven Grunza
Products Engineer
CTDI | Products Division
1373 Enterprise Dr.
West Chester, PA 19380
phone: 610-793-8527
e-mail: sgrunza at ctdi.com <mailto:jhomsey at ctdi.com%7C>
A: Because it messes up the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing in e-mail?
[mailto:rtems-users-bounces at rtems.org] On Behalf Of manish jain
Sent: Thursday, February 07, 2013 6:22 AM
To: rtems-users at rtems.org
Subject: Error while building gcc for toolset for RTEMS
Hi,
I just started working on RTEMS development adn trying to build it.
Before building the RTEMS I am first building the required toolset. My
host is ubuntu so I am building everything from source code. I have been
able to build autoconf,automake,binutils,mps,gmp,mpfr successfully. But
when I am building the gcc for target as sparc I am getting the
following error:
configure: error: cannot compute suffix of object files: cannot compile
See `config.log' for more details.
make[1]: *** [configure-target-libgcc] Error 1
make[1]: Leaving directory `/home/manish/tools/b-gcc'
Can anybody tell me the source of this problem? I am using gcc-4.7.2 and
attaching the "config.log" with this mail.
Thanks
Manish
URL: <http://lists.rtems.org/pipermail/users/attachments/20130207/09052622/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.rtems.org/pipermail/users/attachments/20130207/09052622/attachment.jpg>
