Error while building gcc for toolset for RTEMS
manish jain
manish8886 at gmail.com
Sat Feb 9 03:55:02 UTC 2013
Ok,
Let me check it once again..Thank you.
On Fri, Feb 8, 2013 at 10:39 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
> I am replying from my phone and can't check the source but I think that test for the compiler wants to link not just -c and produce a .o.
> Check the section of the configure script where the probe fails. It is just a shell script and fairly easy to see what it is trying to do.
> --joel
> manish jain <manish8886 at gmail.com> wrote:
> Hi Joel,
> I am able to compile with sparc-rtems-4.11 and I think my PATH variable is
> also working.
> But I dunno why configuration file for *"{Build-Dir}/sparc-rtems4.11/c/sis/"
> * is not showing "/opt/rtems-4.11/bin"in it's PATH variables.
> I am attaching this config(in which errors are coming) with this mail for
> your reference.
> But the surprised thing is that the same PATH values are recognizable in *
> "{Build-Dir}/sparc-rtems4.11/config.log"* which is generating the above
> log.
> On Fri, Feb 8, 2013 at 10:17 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com>wrote:
>> Stupid questions...
>> Are you doing the echo $PATH in the same window based the configure?
>> Can you compile a simple empty main() {} with sparc-rtems4.11-gcc?
>> Is there a more detailed message on config.log?
>> --joel
>> Hi,
>> My $PATH is
>> /opt/rtems-4.11/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
>> And I do have various binaries in /opt/rtems-4.11/bin like:
>> sparc-rtems4.11-gcc
>> sparc-rtems4.11-gcc-4.7.2
>> sparc-rtems4.11-gcc-ar
>> sparc-rtems4.11-gcc-nm
>> sparc-rtems4.11-gcc-ranlib
>> On Fri, Feb 8, 2013 at 9:54 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> What do you get to from:
>>> echo $PATH
>>> which sparc-rtems4.11-gcc
>>> On Feb 8, 2013 9:41 PM, "manish jain" <manish8886 at gmail.com> wrote:
>>> No that didn't also work
>>>> *checking for style of include used by make... GNU
>>>> checking for sparc-rtems4.11-gcc... no
>>>> configure: error: no acceptable cc found in $PATH
>>>> make[2]: *** [sis] Error 1
>>>> make[2]: Leaving directory
>>>> `/home/manish/tools/b-rtems/sparc-rtems4.11/c'
>>>> make[1]: *** [all-recursive] Error 1
>>>> make[1]: Leaving directory
>>>> I checked the path /opt/rtem-4.11 has sparc-rtems4.11-gcc.
>>>> Is there might be problem in configuring the rtems project. I first did
>>>> ./bootstrap from rtems source directory and then configure the rtems and
>>>> tried to build it.
>>>> Thanks
>>>> Manish
>>>> On Fri, Feb 8, 2013 at 10:16 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> 4.11 currently refers to the development head, or master. There is no
>>>>> 4.11 branch at the moment. Try the master branch.
>>>>> The tools are specific to rtems version, so 4.11 tools will not build
>>>>> rtems 4.10.x
>>>>> -Gedare
>>>>> On Feb 8, 2013 4:57 AM, "manish jain" <manish8886 at gmail.com> wrote:
>>>>>> Hi All,
>>>>>> Thanks for all your suggestions. The problem was, library cache was
>>>>>> not updated. Now I have successfully built my tool chains for rtems-4.11.
>>>>>> But now I am facing problem in building the RTEMS itself.
>>>>>> I have built my tool set for rtems-4.11 but I am not able to find
>>>>>> RTEMS-4.11 source code in git repository and CVS. All I see is that most
>>>>>> current version is rtems.4.10.2. So I downloaded the code for rtems-4.10.2
>>>>>> and tried to build it.
>>>>>> I am configuring the rtems with following command:
>>>>>> * ../rtems-4.10.2/configure --target=sparc-rtems4.11
>>>>>> --enable-rtemsbsp=sis --disable-posix --disable-networking --disable-cxx
>>>>>> --prefix=/opt/rtems-4.11
>>>>>> And the error I got when I do make all is following:
>>>>>> *configure: error: no acceptable cc found in $PATH
>>>>>> Actually after getting the error I saw "*
>>>>>> {build-dir/sparc-rtems4.11/c/sis/config.log}*" and problem was that
>>>>>> in PATH: it is not including "/opt/rtems-4.11/bin" but in *
>>>>>> "{build-dir/sparc-rtems4.11/c/config.log}*" the PATH variable is
>>>>>> proper.
>>>>>> And my PATH variable is set to : *
>>>>>> I have looked the previous mails regarding this problem and most
>>>>>> common cause of this error was PATH variable but I think my PATH variable
>>>>>> is proper. I am not able to figure out why it is happening?
>>>>>> Thanks
>>>>>> Manish
>>>>>> On Thu, Feb 7, 2013 at 10:19 AM, Steven Grunza <sgrunza at ctdi.com>wrote:
>>>>>>> > -----Original Message-----
>>>>>>> > From: rtems-users-bounces at rtems.org [mailto:rtems-users-
>>>>>>> > bounces at rtems.org] On Behalf Of Gedare Bloom
>>>>>>> > Sent: Thursday, February 07, 2013 9:52 AM
>>>>>>> > To: manish jain
>>>>>>> > Cc: RTEMS
>>>>>>> > Subject: Re: Error while building gcc for toolset for RTEMS
>>>>>>> > Aside from the (relatively useful) advice that you may want to try
>>>>>>> > the prepackaged solutions, if you continue with building your own
>>>>>>> > tools you may want to check that mpc/gmp/mpfr are being found. If
>>>>>>> > you built/installed them separately from GCC then you need to add
>>>>>>> > the install point to your library path, e.g. export
>>>>>>> > LD_LIBRARY_PATH=${PREFIX}/lib:${LD_LIBRARY_PATH} for PREFIX equal
>>>>>>> > to where you installed those libraries. If you are using a single-
>>>>>>> > tree build where you link the source for those libraries, then gcc
>>>>>>> > should find them itself. The error you sent is indicative of a
>>>>>>> > missing library.
>>>>>>> If you continue on the path of building your own tools, the command
>>>>>>> "ldconfig -p" is your friend. This command will show you all the
>>>>>>> libraries known and cached. If you installed a library from source
>>>>>>> and
>>>>>>> don't see it listed, you may need to run "ldconfig" as root to update
>>>>>>> the cache. I've mostly seen this out-of-date ld.so cache problem on
>>>>>>> Fedora/CentOS systems but it can't hurt to check.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130208/1154ed35/attachment.html>
