Error while building gcc for toolset for RTEMS
Ralf Corsepius ralf.corsepius at rtems.org
Sun Feb 10 11:16:32 UTC 2013
On 02/10/2013 01:33 AM, Joel Sherrill wrote:
> Over the years I have thought about writing a shell script that checked very basic things in the environment. There are a handful of common issues which are easy to resolve once you spot them
One lesson learnt over the years:
The only way to be sure to use a "clean build environment" is to use a
"clean environment" having been set up from _scratch_ as part of the
build-process, such as building in chroots, clean VMs.
Ralf
