RTEMS on a softcore
    Gedare Bloom
    gedare at rtems.org
    Fri Feb 15 14:17:08 UTC 2013
And you could probably attempt to use LWIP on a smaller board, or if
you don't need networking the requirements are much lower also.
On Fri, Feb 15, 2013 at 3:22 AM, Sebastian Huber
> On 02/15/2013 06:46 AM, manish jain wrote:
>> Hi,
>> I just want to know what capabilities a FPGA must have for running RTOS
>> upon
>> it. I purchased
>> "https://www.digilentinc.com/Products/Detail.cfm?NavPath=2,400,790&Prod=BASYS2".
>> Is
>> this FPGA good enough??
> It depends on what you want to do with it.  With the standard RTEMS network
> stack I would say you need 512KiB ROM and 256KiB RAM as a minimum.
> rtems-users mailing list
> rtems-users at rtems.org
