RTEMS on a softcore
    Gedare Bloom
    gedare at rtems.org
    Fri Feb 15 17:06:02 UTC 2013
On Fri, Feb 15, 2013 at 11:57 AM, Mathew Benson <mathew.benson at gmail.com> wrote:
> I've done a little research.  First, you need a soft core.  I know
> Xilinx offers their own Microblaze core and an ARM core, but I don't
> think the ARM core is offered for the Spartan.  It definitely wouldn't
> be free.  I may be wrong, but I think Xilinx offers node locked
> Microblaze cores for free on specific boards who's manufacturers have
> made arrangements with Xilinx.  I don't know if the Basys 2 is one of
> them.  Xilinx also offers another free Microblaze core but its a
> microcontroller.  I assume it doesn't have an MMU and I assume RTEMS
> requires one.
RTEMS does not require an MMU. In fact an MMU makes it more
complicated to get RTEMS to work since the BSP developer must
implement the MMU handling capabilities.
I will also once again plug the Leon core, which has FPGA
synthesizable versions and is well-known in the RTEMS community.
There are also a few developers working with RTEMS on the NIOS II.
-Gedare
> If you can't use the Microblaze, take a look at
> http://www.opencores.com.  I plan on purchasing an FPGA next week and
> was going to look at some of the open cores on that website.
> Then you need enough memory to run RTEMS.  I feel bad... I haven't
> found the time to actually play with RTEMS yet.  I'm trying though.
> You'll also need a BSP to match up RTEMS with your core and board.
> Lastly, you'll need a build tool chain that supports your core.  That
> might be the driving requirement when you're looking at soft cores.
> Please keep us informed.
> On Fri, Feb 15, 2013 at 8:17 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> And you could probably attempt to use LWIP on a smaller board, or if
>> you don't need networking the requirements are much lower also.
>> On Fri, Feb 15, 2013 at 3:22 AM, Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>>> On 02/15/2013 06:46 AM, manish jain wrote:
>>>> Hi,
>>>> I just want to know what capabilities a FPGA must have for running RTOS
>>>> upon
>>>> it. I purchased
>>>> "https://www.digilentinc.com/Products/Detail.cfm?NavPath=2,400,790&Prod=BASYS2".
>>>> Is
>>>> this FPGA good enough??
>>> It depends on what you want to do with it.  With the standard RTEMS network
>>> stack I would say you need 512KiB ROM and 256KiB RAM as a minimum.
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone   : +49 89 189 47 41-16
>>> Fax     : +49 89 189 47 41-09
>>> E-Mail  : sebastian.huber at embedded-brains.de
>>> PGP     : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
