Problems in boot_card() with configuration
Matthew J Fletcher amimjf at gmail.com
Fri Feb 15 19:54:41 UTC 2013
Hi,
I've been reading the online documentation (one of the best bits of
RTEMS, imho), and reading code as well and have a better understanding
of my problems.
I might be using RTEMS in a slightly odd way, i configured for the
rtl22xx BSP as thats pretty close to my board, but i did not build the
samples, i then linked librtemscpu.a and librtemsbsp.a against my codebase.
What i failed to fully grasp that you need create an instance of various
global structures like;
Configuration
Configuration_RTEMS_API
This is needs to be done via a set of defines like follows,..
Although i guess you could poke at the global structures in the
'Configuration' blocks before boot_code().
---------- snip ------------
#include <bsp.h>
#define CONFIGURE_IDLE_TASK_BODY rtems_idle
/* NOTICE: the clock driver is explicitly disabled */
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
#define CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS
 * define OS memory consumption here, RTEMS is pretty lean, but dont go
bonkers
#define CONFIGURE_MAXIMUM_TASKS				20
#define CONFIGURE_MAXIMUM_TIMERS			20
#define CONFIGURE_MAXIMUM_SEMAPHORES		20
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES	20
#define CONFIGURE_MAXIMUM_PARTITIONS		5
#define CONFIGURE_MAXIMUM_REGIONS			5
#define CONFIGURE_MAXIMUM_PORTS				0
#define CONFIGURE_MAXIMUM_PERIODS			0
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS	0
#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
--------- snip --------------
Its also crucialy important to only have one "#define CONFIGURE_INIT
#include <rtems/confdefs.h>" and have it in your application and not in
some sample or test linked against in error.
- Matthew
On 15/02/13 14:24, Joel Sherrill wrote:
> Hmmm.. So you ended up with the default configuration info.. Just there to ensure things link..
> Folks.. Any ideas?
> Matthew J Fletcher <amimjf at gmail.com> wrote:
> Joel,
> I simply had not put
> Anywhere in the code,  bit of a schoolboy error so the Configuration
> structure was not setup. I was creating my own bsp and just forgot that
> I needed bits from on of the samples as well.
> On 15 Feb 2013 14:10, "Joel Sherrill" <Joel.Sherrill at oarcorp.com
> <mailto:Joel.Sherrill at oarcorp.com>> wrote:
>     Could you post or privately email the broken code? I am curious if we can do anything to help avoid this or at least make it easier to debug or know what tolook for in the future.
>     Thanks
>     Matthew J Fletcher <amimjf at gmail.com <mailto:amimjf at gmail.com>> wrote:
>     Thanks all, but my problem was much simpler, not including
>     confdefs.h I copied one of the included samples and am getting much
>     further.
>     On 14 Feb 2013 20:14, "Joel Sherrill" <joel.sherrill at oarcorp.com
>     <mailto:joel.sherrill at oarcorp.com>> wrote:
>         On 2/14/2013 2:00 PM, Matthew J Fletcher wrote:
>             On 14/02/13 19:38, Gedare Bloom wrote:
>                 On Thu, Feb 14, 2013 at 2:16 PM, Joel Sherrill
>                     On 2/14/2013 1:09 PM, Matthew J Fletcher wrote:
>                         Hi,
>                         I am using RTEMS 4.10.2, and a custom BSP based
>                         on the ARM rtl22xx.
>                         I am running through the asm startup ok and
>                         calling into boot_card(),
>                         stepping through its all working fine,
>                         work_area_start, work_area_size,
>                         heap_start and heap_size are setup as i expect
>                         from my linkscript.
>                         But the test of "work_area_size <=
>                         Configuration.work_space_size" fails
>                         because Configuration.work_space_size looks like
>                         0xfffffff, the only
>                         place that assigns to
>                         Configuration.work_space_size is a few lines
>                         further down.
>                         Does this code presume that the BSP has set the
>                         Configuration structure
>                         to zero, or the whole memory ? even so the
>                         aforementioned test seems odd
>                         as its just testing memory has been initialised.
>                 We do assume the .bss section is initialized to 0,
>                 although I'm not
>                 sure if that is still a necessary assumption. But I
>                 don't think that
>                 is the problem here, because if the value of
>                 Configuration.work_space_size was 0 then this test would
>                 still fail.
>                 The work_space_size calculation is done in the
>                 cpukit/sapi/include/confdefs.h file, but that can be a
>                 bit messy to
>                 try to figure out.
>                         Or am i missing some RTEMS initialisation call
>                         that needs to be done
>                         before boot_card() ?
>                     No but there may be some basic C language
>                     assumptions not
>                     being met. Configuration is in the .data section and
>                     that value
>                     does not look like it was initialized to.
>                     Is your download correct?
>                 You can disassemble your binary image and inspect the
>                 value of the
>                 Configuration.work_space_size field in the data section.
>             Sorry i dont seem to have the objdump skills, i did a -D
>             (disassemble
>             all sections), although it produced massive output i dont see a
>             structure called 'Configuration', i get a block like
>             814085f4 <Configuration>:
>             814085f4:       00000000        andeq   r0, r0, r0
>             814085f8:       00010830        andeq   r0, r1, r0, lsr r8
>         This isn't code but this is enough to see that what is in memory
>         and used
>         by the code is NOT what was in the object. The workspace_address
>         field
>         is 0. The second field is the size and is 0x00010830. You saw
>         0xFFFFFFFFF.
>         Either the download didn't go where you thought, memory access isn't
>         setup write, etc.
>         Download and look at those two addresses BEFORE you run at all.
>         If you don't see those values, it is nothing to do with RTEMS. :)
>         .bss is uninitialized global and static date. It gets zeroed.
>         .data is your global and static data that is initialized.
>             814085fc:       00000000        andeq   r0, r0, r0
>             81408600:       00002710        andeq   r2, r0, r0, lsl r7
>             81408604:       00000032        andeq   r0, r0, r2, lsr r0
>             81408608:       8118d3a0        tsthi   r8, r0, lsr #7
>             8140860c:       00001000        andeq   r1, r0, r0
>             81408610:       00001000        andeq   r1, r0, r0
>             81408620:       00000002        andeq   r0, r0, r2
>             81408624:       00000002        andeq   r0, r0, r2
>             81408628:       8140868c        smlalbbhi       r8, r0, ip, r6
>             8140862c:       00000001        andeq   r0, r0, r1
>             81408630:       8140866c        cmphi   r0, ip, ror #12
>             is it possible to pretty print that in some way ?
>                         - Matthew
>                         _________________________________________________
>                         rtems-users mailing list
>                         rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>                         http://www.rtems.org/mailman/__listinfo/rtems-users
>                         <http://www.rtems.org/mailman/listinfo/rtems-users>
>                     Joel Sherrill, Ph.D.             Director of
>                     Research & Development
>                     joel.sherrill at OARcorp.com        On-Line
>                     Applications Research
>                     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>                     Support Available                (256) 722-9985
>         Joel Sherrill, Ph.D.             Director of Research & Development
>         joel.sherrill at OARcorp.com        On-Line Applications Research
