Problems in boot_card() with configuration
Fri Feb 15 23:15:56 UTC 2013
I think we could set the default values to some poison constant and
check that in early boot.
On Fri, Feb 15, 2013 at 5:25 PM, Chris Johns <chrisj at rtems.org> wrote:
> Joel Sherrill wrote:
>> Hmmm.. So you ended up with the default configuration info.. Just there to
>> ensure things link..
>> Folks.. Any ideas?
> Can the default values be so wrong it cannot run or should there be a field
> or bit that is set when a user's config is being used and an internal error
> which indicate the problem is raised if not set.
> Chris
> rtems-users mailing list
> rtems-users at rtems.org
