Problems in boot_card() with configuration
Joel Sherrill Joel.Sherrill at OARcorp.com
Sat Feb 16 00:18:45 UTC 2013
We can do that or use something like shared/bspinit.c and have an Init task which  calls main() plus sets unified work areas and unlimited. With clock tick and console drivers. main() arguments come via bsp command line support.
Gedare Bloom <gedare at rtems.org> wrote:
I think we could set the default values to some poison constant and
check that in early boot.
On Fri, Feb 15, 2013 at 5:25 PM, Chris Johns <chrisj at rtems.org> wrote:
> Joel Sherrill wrote:
>> Hmmm.. So you ended up with the default configuration info.. Just there to
>> ensure things link..
>> Folks.. Any ideas?
> Can the default values be so wrong it cannot run or should there be a field
> or bit that is set when a user's config is being used and an internal error
> which indicate the problem is raised if not set.
> Chris
> rtems-users mailing list
> rtems-users at rtems.org
