BSP instructions
Sun Feb 17 20:11:23 UTC 2013
Hi,
For BSP development the best resource is the BSP and Device Driver
Guide [1]. It might be a little out-dated, especially with some of the
ARM infrastructure which has undergone a lot of changes since 4.10.
The Raspberry Pi board will likely have a BSP soon. Alan Cudmore has a
basic BSP working with a console and clock driver. You can contact him
if you would like to try helping or to encourage a quicker release :)
[1] http://rtems.org/onlinedocs/doc-current/share/rtems/html/bsp_howto/bsp_howto.html
-Gedare
On Sun, Feb 17, 2013 at 2:57 PM, Mathew Benson <mathew.benson at gmail.com> wrote:
> I finally found the time to start playing with RTEMS.  I'm a flight
> software engineer, but have never written a BSP from scratch.  I've
> only tweaked existing ones.  I have a Raspberry Pi B and would like to
> use that as my test bed.  Raspberry Pi is ARM based.  It appears the
> generic RTEMS ARM BSP is deprecated and has been removed.  Two
> questions.  First, is there a tutorial, wiki, or some sort of
> documentation on how to create a BSP?  Second, which BSP should I
> start with?
> rtems-users mailing list
> rtems-users at rtems.org
