_Heap_Initialize called twice, crashes second time around
Tue Feb 19 15:15:27 UTC 2013
Heap Initialize is reused to initialize the RTEMS workspace, and the C
program heap. This is normal when the workspace and heap are separate
(non-unified). Check that your workspace and heap are indeed distinct
in your memory layout (linkcmds) and non-overlapping. Crashes can
happen when they overlap or when the malloc heap pointer is bogus.
-Gedare
On Tue, Feb 19, 2013 at 7:05 AM, Matthew J Fletcher <amimjf at gmail.com> wrote:
> Hi,
> I am not passing any particularly non-standard configure options,
> "--disable-cxx --disable-posix --disable-itron --enable-networking
> --target=arm-rtemseabi4.11 --enable-rtemsbsp=rtl22xx_t".
> 1st callstack
> boot_card()
> -> rtems_initialize_data_structures()
>   -> _Workspace_Handler_initialization()
>     -> _Heap_Initialize()
> 2nd callstack
> boot_card()
> -> bootcard_bsp_libc_helper()
>   -> bsp_libc_init()
>     -> RTEMS_Malloc_Initalize()
>       -> _Heap_Initalize()
> Is this BSP not configured quite right ?
> regards
> Matthew J Fletcher
> rtems-users mailing list
> rtems-users at rtems.org
