Crash in _User_extensions_Thread_create
Thu Feb 21 14:33:24 UTC 2013
On 02/21/2013 02:45 PM, Matthew J Fletcher wrote:
> Sebastian,
> Ok, i've got the latest GIT sources, but i still dont see how the rtl22xx BSP
> works (and it does not work for me).
> start.s does not do any data section copy, it just does a zero'ing of the bss
> and then calls boot_card(), how can that work with initialised data ?
> the start.s thats in the arm/shared folder calls the bsp_start_hook_1 which
> does the bsp_start_copy_sections() which uses the hand rolled memcpy function
> to copy data as well as other sections.
> Is the rtl22xx just a broken BSP that i should not be using ?
I think the best long term solution would be to use the shared start.S for this
BSP.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
