ARM (Thumb Mode) _CPU_Context_switch_arm
Matthew J Fletcher
amimjf at gmail.com
Mon Feb 25 16:47:25 UTC 2013
Hi,
r2 is 0x13 before the msr, so I guess new_level must have been 0.
On 25 Feb 2013 15:02, "Sebastian Huber" <sebastian.huber at embedded-brains.de>
wrote:
> On 02/25/2013 03:15 PM, Matthew J Fletcher wrote:
>> Sebastian,
>> The _Thread_Heir->Registers are ok into the _Context_Switch() call, sp
>> and lr
>> both sensible.
>> At the 'mrs r2, cpsr' line sp is 0x40001b2c (rubbish) and pc sensible.
>> In _restore, after the 'ldmia r1, ...' instruction the sp and lr are
>> loaded
>> with the correct values from _Thread_Heir->Registers.
>> Its the 'msr cpsr, r2' messes up the sp and lr
> Ok, if you load undefined values into the CPSR, then a lot of things may
> happen. What is the value of r2 before the msr? It should be 0x13.
> I think there is a bug in
> void _CPU_Context_Initialize(
> Context_Control *the_context,
> void *stack_area_begin,
> size_t stack_area_size,
> uint32_t new_level,
> void (*entry_point)( void ),
> bool is_fp
> the_context->register_sp = (uint32_t) stack_area_begin + stack_area_size;
> the_context->register_lr = (uint32_t) entry_point;
> the_context->register_cpsr = new_level | arm_cpu_mode;
> if new_level != 0. Is this the case here?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
URL: <http://lists.rtems.org/pipermail/users/attachments/20130225/70d8cd18/attachment.html>
