Error while building gcc for toolset for RTEMS
Joel Sherrill Joel.Sherrill at OARcorp.com
Sun Feb 10 01:46:34 UTC 2013
Cool!!
I recall various environment variables conflicting with the tools like LIB and a GCC path variable, native GCC failing, ncurses for gdb, and makeinfo missing. This assumes the source builder is using its own versions of the various libraries GCC depends on these days.
Chris Johns <chrisj at rtems.org> wrote:
Joel Sherrill wrote:
> Over the years I have thought about writing a shell script that checked very basic things in the environment. There are a handful of common issues which are easy to resolve once you spot them
The Source Builder has a command [1]. It is currently specific to the
set up need to build tools but it could be extended to handle what ever
you want.
[1]
http://www.rtems.org/ftp/pub/rtems/people/chrisj/source-builder/source-builder.html#_checker_sb_check
