Error while building gcc for toolset for RTEMS
    manish jain
    manish8886 at gmail.com
    Sun Feb 10 03:06:06 UTC 2013
Hi Andrei,
Yup I had gcc also but I think this was not the problem in my case because
it was recognizing the sprc-rtemsgcc(Gcc for RTEMS tool chain). Though now
my code has started to build but I need to see what fix made it to work.I
will post it as soon as I figure out.
On Sat, Feb 9, 2013 at 7:31 PM, Andrei Chichak <groups at chichak.ca> wrote:
> Just for laughs, do you have the native C compiler on the system? Like gcc?
> I noticed a while ago that I couldn't get anything to work because
> configure was looking for gcc, not the gcc for RTEMS, gcc for Linux. I did
> an install of gcc and away it went.
> Andrei
> On 2013-February-08, at 7:41 PM, manish jain wrote:
> No that didn't also work
> *checking for style of include used by make... GNU
> checking for sparc-rtems4.11-gcc... no
> configure: error: no acceptable cc found in $PATH
> make[2]: *** [sis] Error 1
> make[2]: Leaving directory `/home/manish/tools/b-rtems/sparc-rtems4.11/c'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/manish/tools/b-rtems/sparc-rtems4.11/c'
> I checked the path /opt/rtem-4.11 has sparc-rtems4.11-gcc.
> Is there might be problem in configuring the rtems project. I first did
> ./bootstrap from rtems source directory and then configure the rtems and
> tried to build it.
> Thanks
> Manish
URL: <http://lists.rtems.org/pipermail/users/attachments/20130209/fcbadee2/attachment-0001.html>
