RTEMS on a softcore
Yann Sionneau yann at minet.net
Sun Feb 10 15:20:16 UTC 2013
Hi,
RTEMS runs on the Milkymist One board.
Milkymist One is featuring a Spartan-6 FPGA.
You can run the Milkymist SoC (containing a LM32 softcore) on this FPGA
which then can run RTEMS 4.11
Actually Milkymist One board is shipped pre-flashed with Milkymist SoC
and with Flickernoise software which is an application based on RTEMS 4.11.
More informations about Milkymist One board over there:
- http://en.wikipedia.org/wiki/Milkymist#Milkymist_One
- http://milkymist.org/3/mmone.html
Cheers :)
Le 10/02/13 16:11, Joel Sherrill a écrit :
> I had a partially complete port to the Microblaze on a branch. It was almost doing context switches correctly. It is a good opportunity to contribute. If you are interested, I can update and republish it.
> The leon3 is a soft core and we have great support for it.
> The virtex families have BSPs.
> We have a port to the Opencores OpenRISC but at the time they couldn't keep GCC compiling for their target and we ended up deprecating it. It could be resurrected fairly easily if the tool situation has improved.
> Any others?
> --joel
> Gedare Bloom <gedare at rtems.org> wrote:
> There are a few efforts to do a microblaze port, but I have not heard
> much about the progress. There are also virtex 4 and 5 BSPs (PPC hard
> cores) available.
> -Gedare
> On Feb 10, 2013 8:03 AM, "Mathew Benson" <mathew.benson at gmail.com
> <mailto:mathew.benson at gmail.com>> wrote:
>     Has anybody got RTEMS to run on an inexpensive FPGA based board?
>      I'm looking at:
>     http://www.xilinx.com/products/boards-and-kits/AES-S6MB-LX9.htm
>     Does anybody have a BSP for this?  Any inexpensive Altera boards?
