VT100 on QEMU?
Gedare Bloom
gedare at rtems.org
Thu Feb 14 15:56:14 UTC 2013
On Thu, Feb 14, 2013 at 4:26 AM, Mogens Dybæk Christensen
<MogensD.Christensen at man.eu> wrote:
>> -----Original Message-----
>> From: rtems-users-bounces at rtems.org [mailto:rtems-users-
>> bounces at rtems.org] On Behalf Of Sebastian Huber
>> Sent: 14. februar 2013 09:39
>> To: rtems-users at rtems.org
>> Subject: Re: VT100 on QEMU?
>> On 02/13/2013 01:41 PM, Mogens Dybæk Christensen wrote:
>> > Hello Sebastian
>> > We just want a terminal window that can interpret VT100 escape-
>> sequences for cursor movement etc.
>> > We are porting a menu system that uses them.
>> So you want to send a character stream from the program running on Qemu
>> to a
>> consumer that acts as a VT100 terminal? Do you use Qemu on Windows or
>> Linux?
> I run QEMU on Linux. The console offered by QEMU works fine for simple text (like in RTEMS tests), but the cursor movement commands are not interpreted. - They are just printed. :-)
> We have a workaround now: Build with the "unix" RTEMS BSP and debug with qtcreator. qtcreator can redirect the console to an xterm-like window that does emulate VT100.
What version of RTEMS are you using? The unix BSP is a relic...
> /Mogens
> rtems-users mailing list
