VT100 on QEMU?
Gedare Bloom
gedare at rtems.org
Thu Feb 14 17:17:16 UTC 2013
On Thu, Feb 14, 2013 at 11:27 AM, Mogens Dybæk Christensen
<MogensD.Christensen at man.eu> wrote:
>> -----Original Message-----
>> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of
>> Gedare Bloom
>> Sent: 14. februar 2013 16:56
>> To: Mogens Dybæk Christensen
>> Cc: Sebastian Huber; rtems-users at rtems.org
>> Subject: Re: VT100 on QEMU?
>> On Thu, Feb 14, 2013 at 4:26 AM, Mogens Dybæk Christensen
>> >> From: rtems-users-bounces at rtems.org [mailto:rtems-users-
>> >> bounces at rtems.org] On Behalf Of Sebastian Huber
>> >> Sent: 14. februar 2013 09:39
>> >> To: rtems-users at rtems.org
>> >> On 02/13/2013 01:41 PM, Mogens Dybæk Christensen wrote:
>> >> > Hello Sebastian
>> >> > We just want a terminal window that can interpret VT100 escape-
>> >> sequences for cursor movement etc.
>> >> > We are porting a menu system that uses them.
>> >> So you want to send a character stream from the program running on
>> Qemu
>> >> to a
>> >> consumer that acts as a VT100 terminal? Do you use Qemu on Windows
>> or
>> >> Linux?
>> > I run QEMU on Linux. The console offered by QEMU works fine for
>> simple text (like in RTEMS tests), but the cursor movement commands are
>> not interpreted. - They are just printed. :-)
>> > We have a workaround now: Build with the "unix" RTEMS BSP and debug
>> with qtcreator. qtcreator can redirect the console to an xterm-like
>> window that does emulate VT100.
>> What version of RTEMS are you using? The unix BSP is a relic...
> 4.11
I did not think 4.11 has the unix BSP. Did you import it from an older
repository?
