Problems in boot_card() with configuration
Fri Feb 15 22:25:23 UTC 2013
Joel Sherrill wrote:
> Hmmm.. So you ended up with the default configuration info.. Just there to ensure things link..
> Folks.. Any ideas?
Can the default values be so wrong it cannot run or should there be a
field or bit that is set when a user's config is being used and an
internal error which indicate the problem is raised if not set.
