Problems in boot_card() with configuration
Chris Johns
chrisj at rtems.org
Sat Feb 16 00:34:37 UTC 2013
Joel Sherrill wrote:
> We can do that or use something like shared/bspinit.c and have an Init task which calls main() plus sets unified work areas and unlimited. With clock tick and console drivers. main() arguments come via bsp command line support.
I think this is a separate issue. We need a way the user gets a clear
indication there is a configuration issue and that needs to be in the
cpukit code and not in BSP boot or init code.
We can add this to bspinit.c how-ever I think your idea of bsp command
line handling needs to also be added so the user can change default
settings. My concern is bspinit.c is about making the entry point 'main'
rather than 'Init' and I would not like to lose the simplicity of this.
Having said this bspinit.c already has the networking stack init hack so
adding command line parsing is not big change. I am not sure about the
drivers that may be too much of a change.
