ARM (Thumb Mode) _CPU_Context_switch_arm
Mon Feb 25 19:53:17 UTC 2013
On 2/25/2013 1:37 PM, Matthew J Fletcher wrote:
> Hi,
> I guess it my fault for not 100% copying the rtl22xx BSP into my new
> one, i had the cpsr register in a different state at boot_card() time
> than the generic ARM context switch code expects. I think that common
> binary blob commercial RTOS must do a cpsr read before the first
> context switch, rather than rely on a fixed state as i've not
> encountered this type of issue before.
Some architectures construct the entire value of the status register. Others
start with what the BSP had and modify it.
The question is which bits mattered and why RTEMS missed them. Could
we generically know the complete set of correct bits to set?
If so, it is definitely safer to compute the entire value of a task's
status register.
--joel
> On 25 Feb 2013 17:40, "Joel Sherrill" <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>> wrote:
>     On 2/25/2013 11:25 AM, Matthew J Fletcher wrote:
>>     Sebastain,
>>     I changed the code so now with the cpsr set as expected before
>>     main() the context switch occurs fine and we end up in Init().
>     Is this a generic issue that needs addressing in the RTEMS
>     git repo? Or something you broke accidentally when making
>     other changes?
>>     Thanks for all your help.
>     A little early for a beer here but it is definitely after 5 for
>     Sebastian. Good job Sebastian!
>     --joel
>>     On 25 February 2013 17:10, Matthew J Fletcher <amimjf at gmail.com
>>     <mailto:amimjf at gmail.com>> wrote:
>>         Hi,
>>         The cpsr thats saved out to r2 is 0x800000df, but is restored
>>         back to 0x13. Thanks for pointing out that no cpsr change
>>         must happen, i will check how the rtl22xx_t bsp sets up the
>>         cpsr.
>>         On 25 February 2013 16:52, Sebastian Huber
>>         <sebastian.huber at embedded-brains.de
>>         <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>             On 02/25/2013 05:47 PM, Matthew J Fletcher wrote:
>>                 Hi,
>>                 r2 is 0x13 before the msr, so I guess new_level must
>>                 have been 0.
>>                 On 25 Feb 2013 15:02, "Sebastian Huber"
>>                 <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>>                     On 02/25/2013 03:15 PM, Matthew J Fletcher wrote:
>>                         Sebastian,
>>                         The _Thread_Heir->Registers are ok into the
>>                 _Context_Switch() call, sp
>>                         and lr
>>                         both sensible.
>>                         At the 'mrs r2, cpsr' line sp is 0x40001b2c
>>                 (rubbish) and pc sensible.
>>                         In _restore, after the 'ldmia r1, ...'
>>                 instruction the sp and lr are loaded
>>                         with the correct values from
>>                 _Thread_Heir->Registers.
>>                         Its the 'msr cpsr, r2' messes up the sp and lr
>>                     Ok, if you load undefined values into the CPSR,
>>                 then a lot of things may
>>                     happen.  What is the value of r2 before the msr?
>>                  It should be 0x13.
>>             Ok, then maybe the mode in the BSP execution context is
>>             wrong.  During _Context_Switch() no mode change must
>>             happen.  What is the CPSR before the msr?
>>             Sebastian Huber, embedded brains GmbH
>>             Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>             Phone   : +49 89 189 47 41-16
>>             <tel:%2B49%2089%20189%2047%2041-16>
>>             Fax     : +49 89 189 47 41-09
>>             <tel:%2B49%2089%20189%2047%2041-09>
>>             E-Mail  : sebastian.huber at embedded-brains.de
>>             PGP     : Public key available on request.
>>             Diese Nachricht ist keine geschäftliche Mitteilung im
>>             Sinne des EHUG.
>>         regards
>>         Matthew J Fletcher
>>     regards
>>     Matthew J Fletcher
>     Joel Sherrill, Ph.D.             Director of Research & Development
>     joel.sherrill at OARcorp.com  <mailto:joel.sherrill at OARcorp.com>         On-Line Applications Research
>     Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>     Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20130225/e40156d5/attachment-0001.html>
