ARM (Thumb Mode) _CPU_Context_switch_arm
Mon Feb 25 20:45:01 UTC 2013
On 2/25/2013 2:14 PM, Matthew J Fletcher wrote:
> Joel,
> _CPU_Context_Initialize in cpu.c uses a hardcoded (to 0x13, not even
> using a #define) arm_cpu_mode variable to define the cpsr.
> #define ARM_PSR_M_SVC 0x13
> from cpu.h might be a good start.
> Although i just noticed the changelog,... oops.
> 2008-04-17	Joel Sherrill <joel.sherrill at oarcorp.com>
> 	* cpu.c: Add arm_cpu_mode so ARM BSP can overrid default value for cpsr.
> Maybe if this was an extern and the BSP defined the variable and
> initialised it it would be easier to notice. I never thought of looking
> in cpu.c for places to modify.
Wow! I don't remember that change at all. It doesn't even sound like the
way I would normally solve this problem. :(
Sebastian.. do you remember this?
is there a better way to accomplish this?
> On 25/02/13 19:53, Joel Sherrill wrote:
>> On 2/25/2013 1:37 PM, Matthew J Fletcher wrote:
>>> Hi,
>>> I guess it my fault for not 100% copying the rtl22xx BSP into my new
>>> one, i had the cpsr register in a different state at boot_card() time
>>> than the generic ARM context switch code expects. I think that common
>>> binary blob commercial RTOS must do a cpsr read before the first
>>> context switch, rather than rely on a fixed state as i've not
>>> encountered this type of issue before.
>> Some architectures construct the entire value of the status register. Others
>> start with what the BSP had and modify it.
>> The question is which bits mattered and why RTEMS missed them. Could
>> we generically know the complete set of correct bits to set?
>> If so, it is definitely safer to compute the entire value of a task's
>> status register.
>> --joel
>>> On 25 Feb 2013 17:40, "Joel Sherrill" <joel.sherrill at oarcorp.com
>>> <mailto:joel.sherrill at oarcorp.com>> wrote:
>>>      On 2/25/2013 11:25 AM, Matthew J Fletcher wrote:
>>>>      Sebastain,
>>>>      I changed the code so now with the cpsr set as expected before
>>>>      main() the context switch occurs fine and we end up in Init().
>>>      Is this a generic issue that needs addressing in the RTEMS
>>>      git repo? Or something you broke accidentally when making
>>>      other changes?
>>>>      Thanks for all your help.
>>>      A little early for a beer here but it is definitely after 5 for
>>>      Sebastian. Good job Sebastian!
>>>      --joel
>>>>      On 25 February 2013 17:10, Matthew J Fletcher <amimjf at gmail.com
>>>>      <mailto:amimjf at gmail.com>> wrote:
>>>>          Hi,
>>>>          The cpsr thats saved out to r2 is 0x800000df, but is restored
>>>>          back to 0x13. Thanks for pointing out that no cpsr change
>>>>          must happen, i will check how the rtl22xx_t bsp sets up the
>>>>          cpsr.
>>>>          On 25 February 2013 16:52, Sebastian Huber
>>>>          <sebastian.huber at embedded-brains.de
>>>>          <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>>>              On 02/25/2013 05:47 PM, Matthew J Fletcher wrote:
>>>>                  Hi,
>>>>                  r2 is 0x13 before the msr, so I guess new_level must
>>>>                  have been 0.
>>>>                  On 25 Feb 2013 15:02, "Sebastian Huber"
>>>>                  <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>>>>                      On 02/25/2013 03:15 PM, Matthew J Fletcher wrote:
>>>>                          Sebastian,
>>>>                          The _Thread_Heir->Registers are ok into the
>>>>                  _Context_Switch() call, sp
>>>>                          and lr
>>>>                          both sensible.
>>>>                          At the 'mrs r2, cpsr' line sp is 0x40001b2c
>>>>                  (rubbish) and pc sensible.
>>>>                          In _restore, after the 'ldmia r1, ...'
>>>>                  instruction the sp and lr are loaded
>>>>                          with the correct values from
>>>>                  _Thread_Heir->Registers.
>>>>                          Its the 'msr cpsr, r2' messes up the sp and lr
>>>>                      Ok, if you load undefined values into the CPSR,
>>>>                  then a lot of things may
>>>>                      happen.  What is the value of r2 before the msr?
>>>>                   It should be 0x13.
>>>>              Ok, then maybe the mode in the BSP execution context is
>>>>              wrong.  During _Context_Switch() no mode change must
>>>>              happen.  What is the CPSR before the msr?
>>>>              Sebastian Huber, embedded brains GmbH
>>>>              Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>              Phone   : +49 89 189 47 41-16
>>>>              <tel:%2B49%2089%20189%2047%2041-16>
>>>>              Fax     : +49 89 189 47 41-09
>>>>              <tel:%2B49%2089%20189%2047%2041-09>
>>>>              E-Mail  : sebastian.huber at embedded-brains.de
>>>>              PGP     : Public key available on request.
>>>>              Diese Nachricht ist keine geschäftliche Mitteilung im
>>>>              Sinne des EHUG.
>>>>          regards
>>>>          Matthew J Fletcher
>>>>      regards
>>>>      Matthew J Fletcher
>>>      Joel Sherrill, Ph.D.             Director of Research & Development
>>>      joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com>        On-Line Applications Research
>>>      Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>      Support Available                (256) 722-9985
>> joel.sherrill at OARcorp.com        On-Line Applications Research
