CPU Cost of having Posix API enabled if not used.
Thu Feb 28 16:37:43 UTC 2013
Hello,
On 02/28/2013 05:26 PM, Tom Bojsen wrote:
> Hi,
> Does enabling the Posix interface cost extra CPU cycles if it is not used?
in your version, yes.  In the latest Git master branch, no.  The RTEMS and
POSIX signals need a post thread switch extension.  See end of
_Thread_Dispatch() (_API_extensions_Run_post_switch( executing )):
http://git.rtems.org/rtems/tree/cpukit/score/src/threaddispatch.c
In earlier RTEMS versions the post switch extension was installed during system
start.  Now it is installed on demand.  On systems which frequently switch
threads the post switch overhead is measurable.
http://git.rtems.org/rtems/commit/?id=ba3163131770e730cbf5168333c84daa57bc14e5
http://git.rtems.org/rtems/commit/?id=9465fca287e9417e05d2efe572d770fd60ad61db
An unused POSIX API adds also some dead code.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
