Integrating RTEMS with ARM Cortex R4
Sebastian Huber
Sat Jan 26 22:05:36 UTC 2013
Hello,
you can use the LPC32XX BSP as a template.
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lpc32xx
The current RTEMS 4.11 tool chain supports Thumb-2 ARMv7 code (GCC
options: -mthumb -march=armv7) and ARM ARMv4 code.
On 25/01/13 23:31, Pritesh Gudge wrote:
> Hi,
> I am new to RTEMS. I am using an ARM Cortex R4 CPU which is based on ARMv7,
> This is the wiki page which says that Cortex R4 CPUs are supported.
> http://www.rtems.org/wiki/index.php/ARM-EABI
> I am currently using Texas Instruments Hercules Development Kit which has
> ARM Cortex R4 CPU along with 256 KB SRAM
> and 3MB Flash Memory. It also has 8MB SDRAM. I want to use RTEMS as it is
> excellent for Experimental Physics and Industrial Control System
> http://www.aps.anl.gov/epics/. But I did not find any relevant
> documentation which explains the configuration procedure for ARMv7.
> Could anyone kindly guide me with the relevant procedure and specifics I
> must apply to get RTEMS running on the given Embedded Microcontroller.
> http://www.ti.com/product/tms570ls3137
> Thanks.
> Regards,
> rtems-users mailing list
> rtems-users at rtems.org
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
