Paranoia flaw on pc386
Thu Jul 18 18:37:59 UTC 2013
The compiler flags and optimizations matter a lot on x86.
There are lots of discussions when gcc is benchmarked
against icc like this one:
http://gcc.gnu.org/ml/gcc/2012-01/msg00238.html
But specifically, there is a discussion of gcc and paranoia
here which appears to match your report.
http://gcc.gnu.org/ml/gcc/2004-03/msg01468.html
--joel
On 7/18/2013 1:30 PM, Gedare Bloom wrote:
> I think the FLAWs can be safely ignored, but may be will matter if
> your application uses floating point operations.
> On Thu, Jul 18, 2013 at 2:24 PM, Ardalan Pouyabahar
> <a.pouyabahar at ece.ut.ac.ir> wrote:
>> Hello,
>> Paranoia output on rtems pc386 had 1 flaw which was this:
>> Sticky bit used incorrectly or not at all.
>> TEST: lack(s) of guard digits or failure(s) to correctly round or chop
>> (noted above) count as one flaw in the final tally below
>> ERROR: Severity: FLAW:  lack(s) of guard digits or failure(s) to correctly
>> round or chop
>> (noted above) count as one flaw in the final tally below.
>> PASS: lack(s) of guard digits or failure(s) to correctly round or chop
>> I've searched in rtems mailing list and google but couldn't find anything
>> useful yet. Does anyone know what it means and how can I solve it?
>> I compiled whole rtems and paranoia without optimization.
>> Thanks,
>> A.Pouyabahar
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
