Re: What's the accurate meaning of the macro "RTEMS_MULTIPROCESSING" and "RTEMS_SMP"?
Tue Jul 23 07:33:01 UTC 2013
On 2013-07-23 09:20, Hailin Guo wrote:
> I am porting RTEMS to a multiprocessor CPU whoes architecture is very
> non-mainstream. When I read the source, I am confused about the macro
> "RTEMS_MULTIPROCESSING" and "RTEMS_SMP". And in the document of RTEMS
> Applications C User's Guide, there is also no talk about "RTEMS_SMP".
 > Who can explain to me about the two macros' meaning?
The RTEMS_MULTIPROCESSING is supported for a long time and is also known as
asymmetric multiprocessing.  Here message passing is used to synchronize objects.
The RTEMS_SMP is new to RTEMS and work in progress.  One RTEMS instance will
run on multiple processors.
> And how does RTEMS boot
> from multiprocessor?
At the moment there is no documentation for this.  The realview_pbx_a9_qemu_smp
BSP runs on the Qemu simulator and has SMP support.  You may have a look at the
BSP sources.
See also the comments in percpu.h for Per_CPU_State.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
