RTEMS on Virtex 4
Gempeler Stefan
Stefan.Gempeler at nanotronic.ch
Mon Jun 3 09:43:23 UTC 2013
Hi Sebastian and Joel,,
thank you very much for your fast replies. Sorry if I ruined your
weekend, Joel ;-)
> you execute the program out of the RAM?
Yes, that's the plan. No additional memory (costs).
> printf() and the Termios interface (do you need it?) needs a lot of
code space
> and the PowerPC code itself is not very dense. It is possible to
strip down a
> RTEMS system, but in general RTEMS is not a ultra low code size
system.
I use the printk() to write data to the UART (also changed the printf()
in c/src/lib/libbsp/powerpc/virtex/startup/bspstart.c:
bsp_XAssertHandler() to printk() -> no printf() in elf file).
Hmm, when I set
#define CONFIGURE_TERMIOS_DISABLED
I get no output anymore. We use the UART as a simple debug console
(output can be directly written to UART, input interrupt driven).
> Can you post your hello world version? And how you configured RTEMS.
The changes I made in the virtex BSP c/src/lib/libbsp/powerpc/virtex:
- configure.ac : changed
RTEMS_BSPOPTS_SET([RTEMS_XPARAMETERS_H],[*],[\<xparameters_dflt.h\>]) to
RTEMS_BSPOPTS_SET([RTEMS_XPARAMETERS_H],[*],[\"/home/me/code/ml410/ppc40
5_0/include/xparameters.h\"])
- console/consolelite.c : removed the entries "/dev/ttyS1" to
"/dev/ttyS3" in console_tbl Console_Configuration_Ports[]
- startup/bspstart.c: bsp_XAssertHandler(), printf() to
printk()
- startup/linkcmds:
RamBase = 0xfffc0000;
RamSize = 0x0003ffff;
HeapSize = 0x0;
StackSize = 0x2000;
MEMORY
RAM : ORIGIN = 0xfffc0000, LENGTH = 0x0003ffff
SECTIONS
.text 0xfffc0000:
/* align bottom of 32k init stack at a 32k boundary */
. = . + 0x1000;
. = ALIGN( 0x1000 );
stack.start = .;
. = . + StackSize;
. = . + StackSize;
stack.end = .;
* Interrupt stack setup
IntrStack_start = ALIGN(0x10);
. += StackSize;
IntrStack_end = .;
Configured with :
../rtems/configure --target=powerpc-rtems4.11 --enable-rtemsbsp=virtex
--prefix=/home/me/code/bsp-install --disable-cxx --disable-networking
I tested several hello worlds.
The basic one:
/* forward declarations to avoid warnings */
rtems_task Init(rtems_task_argument argument);
rtems_task Init( rtems_task_argument ignored )
printk( "\n\n*** HELLO WORLD TEST ***\t\t%s, %s\n", __DATE__, __TIME__
printk( "Hello World\t\t\t\t%s, %s\n", __DATE__, __TIME__ );
printk( "*** END OF HELLO WORLD TEST ***\t\t%s, %s\n", __DATE__,
__TIME__ );
exit( 0 );
/* NOTICE: the clock driver is explicitly disabled */
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 1
#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
Size:
text data bss dec hex filename
126392 1724 4004 132120 20418 rtems_libs.exe
To test the POSIX thread creation:
void* dbg_thread(void *arg)
printk( "POSIX: LOCAL dbg_thread()\t%s, %s\n", __DATE__,
__TIME__ );
while(1);
exit( 0 );
rtems_task Init(rtems_task_argument ignored )
printk( "\nClassic -- Hello World\t\t%s, %s\n", __DATE__, __TIME__ );
rtems_task_delete( RTEMS_SELF );
void *POSIX_Init( void *argument )
pthread_t dbg;
printk( "POSIX -- Hello World\t\t%s, %s\n", __DATE__, __TIME__ );
pthread_create( &dbg, NULL, dbg_thread, NULL );
sleep( 1 );
while(1);
exit( 0 );
/* configuration information */
#define CONFIGURE_POSIX_INIT_THREAD_TABLE
(1)
#define CONFIGURE_MAXIMUM_POSIX_THREADS (2)
#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
(CONFIGURE_MAXIMUM_POSIX_THREADS*1024)
Size:
141416 1796 3848 147060 23e74 rtems_libs.exe
These 2 examples worked and produced the output as expected over the
UART defined as STDOUT_BASEADDRESS. Also the input (polled with
getchark ()) worked.
> The PowerPC BSPs should provide this interface:
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__rtems__interr
upt__extension.html
> In case this doesn't work with the virtex4 BSP, then we should fix
this.
I already tried it with rtems_interrupt_handler_install(), but it seems
to be missing in the libs:
undefined reference to `rtems_interrupt_handler_install'
collect2: error: ld returned 1 exit status
virtex4 BSP: at the moment I use the virtex and not the virtex4 BSP
because I don't know how to get the UART stdio working.
How do I set up the stdio and interrupt to STDOUT_BASEADDRESS?
Ok, thank you very much again for your responses and help. I really
appreciate it.
The next step of my evaluation process will be trying to get a lower
memory usage to move on with our tests.
Kind regards
Stefan Gempeler
URL: <http://lists.rtems.org/pipermail/users/attachments/20130603/d62d2775/attachment.html>
