Integrating RTEMS with ARM Cortex R4
Pritesh Gudge priteshgudge at gmail.com
Wed Jun 5 15:17:16 UTC 2013
Sebastian Huber <sebastian.huber at ...> writes:
> On 26/01/13 15:07, Jiri Freyvald wrote:
> > -------- Original Message --------
> > Subject:     Re: Integrating RTEMS with ARM Cortex R4
> > Date:     Sat, 26 Jan 2013 14:01:55 +0000
> > From:     Jiri Freyvald <jiri.freyvald at ...>
> > To:     priteshgudge at ...
> > Pritesh,
> > I have been using RTEMS port for Cortex-M4 and so far it works
> > perfectly for me
> > (namely STM32F4DISCOVERY board, STM32F407 processor)
> > I don't know how close M4 and R4 cores are, but I guess porting BSP
> > from R4 to M4 shouldn't be too difficult.
> The ARMv7-M and ARMv7-R are quite different (e.g. in the ARMv7-M we have
> the mandatory NVIC).
So, as far as I have understood, here are the following points which need to
be considered for RTEMS-based development:
1. Check if the CPU is supported: Cortex-R CPUs are supported as per the
wiki page http://www.rtems.org/wiki/index.php/ARM-EABI
2. Write a BSP for the requisite Board as it is not available for mine -
This part I will figure out in due time.
But kindly confirm statement 1.
I have read your previous comment about the template LPC32XX BSP.
I will be using the Texas Instrument Microcontroller TMS570LS3137 for the
development. http://www.ti.com/product/tms570ls3137
I just need a confirmation whether my understanding to this stage is
correct. Only then will it make sense to commit to developing the requisite
BSP.
Regards,
Pritesh
