GSOC2013-Atomic Operations and SMP lock debug tool
Sebastian Huber
Tue Jun 4 14:28:22 UTC 2013
Hello Hengyi,
On 06/03/2013 05:11 PM, Deng Hengyi wrote:
> Hi Sebastian,
> In original the proposal of the atomic project there is a roadmap of switching to C11 atomic API completely along the time. So if the C11 is mature and used by RTEMS i am very glad to switch to it.
C11 is mature. The question is if the GCC C11 support is mature enough (at
least the features we are interested in). According to wiki page
http://gcc.gnu.org/wiki/C11Status GCC 4.7 was the first supporting C11 atomics.
I suppose we have to add a <stdatomic.h> to Newlib, e.g. the one from FreeBSD:
http://svnweb.freebsd.org/base/head/include/stdatomic.h?view=markup&pathrev=234958
> But i have some concern as below:
> 1. Whether C11 support all the architecture used in RTEMS? (some architectures should not be supported if they are lack of atomic instructions)
I think the atomics are only interesting for RTEMS targets with SMP support.
> 2. If C11 does not support some architecture how to we make the atomic API unified?
If C11 support is not available for an architecture, then this is bad luck for
the architecture vendor.
> 3. Also should consider the UP mode support.
It is highly use case dependent if an UP mode makes sense. If you have for
example a spin lock used in task and interrupt context, then you have to ensure
that the critical section is also protected by disabled interrupts. Some
lock-free list operations on the other hand may work for some architectures
even without disabled interrupts. In general operations performed by
interrupts and tasks should be protected by disabled interrupts. Thus the UP
case is included anyway.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
