Error when building realview_pbx_a9 BSP
Hesham Moustafa
heshamelmatary at gmail.com
Mon Jun 10 12:25:43 UTC 2013
Should I upgrade my OS ?
The latest gcc version I found there [1] for fedora 16 is 4.7
[1] http://www.rtems.com/ftp/pub/rtems/linux/4.11/fedora/16/i386/
On Mon, Jun 10, 2013 at 2:18 PM, Hesham Moustafa
<heshamelmatary at gmail.com>wrote:
> Seems like I have missing libs. The command yields
> /opt/rtems-4.11/arm-rtems4.11/lib/thumb/libc.a
> /opt/rtems-4.11/arm-rtems4.11/lib/thumb/vfp/libc.a
> /opt/rtems-4.11/arm-rtems4.11/lib/libc.a
> /opt/rtems-4.11/arm-rtems4.11/lib/vfp/libc.a
> /opt/rtems-4.11/arm-rtems4.11/lib/softfp/vfp/libc.a
> /opt/rtems-4.11/arm-rtems4.11/lib/fpu/libc.a
> Thanks Sebastian.
> On Mon, Jun 10, 2013 at 1:42 PM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 06/10/2013 11:48 AM, Hesham Moustafa wrote:
>>> Do you mean arm-rtems4.11-gcc cross compiler or my host compiler?
>> The cross compiler.
>> I tried to 'yum update arm-rtems*' but no results. I am using fc16 as I
>>> mentioned before.
>> A "find /opt/rtems-4.11/arm-rtems4.11 -name libc.a" should yield:
>> /opt/rtems-4.11/arm-rtems4.11/**lib/libc.a
>> /opt/rtems-4.11/arm-rtems4.11/**lib/thumb/libc.a
>> /opt/rtems-4.11/arm-rtems4.11/**lib/thumb/armv7/libc.a
>> /opt/rtems-4.11/arm-rtems4.11/**lib/thumb/armv7-r/libc.a
>> /opt/rtems-4.11/arm-rtems4.11/**lib/thumb/armv6-m/libc.a
>> /opt/rtems-4.11/arm-rtems4.11/**lib/thumb/armv7-m/libc.a
>> /opt/rtems-4.11/arm-rtems4.11/**lib/thumb/armv7-m/neon/hard/**libc.a
>> /opt/rtems-4.11/arm-rtems4.11/**lib/thumb/armv7-a/libc.a
>> /opt/rtems-4.11/arm-rtems4.11/**lib/thumb/armv7-a/neon/hard/**libc.a
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130610/7180e218/attachment-0001.html>
