Whats allowed in the Init() task
Matthew J Fletcher amimjf at gmail.com
Fri Mar 1 14:07:32 UTC 2013
Hi,
Do rtems applications normally create a new task straight away in Init() ?
i ask because i seem to get stuck with no threads being scheduled after the
first Clock_isr.
So after boot_card() completes rtems context switches into Init(), there i
setup my 10ms tick ISR which calls rtems_clock_tick(). But the original
thread Init() never gets scheduled again after the first call to
rtems_clock_tick(). I've used JTAG to place breakpoints and i can see the
code in Init() is not being run.
I can see the ISR is being called and the interrupt acknowledged due to
breakpoints there.
Interestingly although i am using the arm-rtemseabi4.11-gdb 'info threads'
only shows the current context of the ISR not the Init() thread, that might
be a different issue though.
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130301/ae696919/attachment.html>
