Whats allowed in the Init() task
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Mar 1 17:10:29 UTC 2013
On 3/1/2013 10:56 AM, Matthew J Fletcher wrote:
> Gedare,
> Yes the "hello" example works fine. I just tried the "ticker" example,
> but rtems_clock_set() returns RTEMS_INVALID_CLOCK. Odd, maybe the
> samples dont get tested very often.
They get run all the time. I am heading off for the weekend but will try to
run it on something I have a simulator for.
> It _TOD_Validate() is rejecting the time set in the example, and i am
> literally using the code from the example. Its returning false at the
> first 'if' test, the big one checking against the constants.
> Is the test for 'the_tod->year < TOD_BASE_YEAR' correct given then are
> equal at 1988 ?
Yes.
> On 1 March 2013 15:40, Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> On Fri, Mar 1, 2013 at 9:07 AM, Matthew J Fletcher
> <amimjf at gmail.com <mailto:amimjf at gmail.com>> wrote:
> > Hi,
> > Do rtems applications normally create a new task straight away
> in Init() ? i
> > ask because i seem to get stuck with no threads being scheduled
> after the
> > first Clock_isr.
> By the time Init gets executed the entire application stack should be
> set up and multithreading/interrupts should work fine. Init can either
> create new tasks, or execute the workload directly.
> > So after boot_card() completes rtems context switches into
> Init(), there i
> > setup my 10ms tick ISR which calls rtems_clock_tick(). But the
> original
> > thread Init() never gets scheduled again after the first call to
> > rtems_clock_tick(). I've used JTAG to place breakpoints and i
> can see the
> > code in Init() is not being run.
> I don't understand what you mean about Init setting up the clock tick.
> The ISR for clock handling should be installed during rtems
> initialization when the clock driver is installed. Have you
> successfully executed the "hello" sample on your board? If so the next
> one to test is ticker, which should give you an idea of whether the
> clock tick + context switch is working.
> -Gedare
> > I can see the ISR is being called and the interrupt acknowledged
> due to
> > breakpoints there.
> > Interestingly although i am using the arm-rtemseabi4.11-gdb
> 'info threads'
> > only shows the current context of the ISR not the Init() thread,
> that might
> > be a different issue though.
> > regards
> > Matthew J Fletcher
> > rtems-users mailing list
> > rtems-users at rtems.org <mailto:rtems-users at rtems.org>
> > http://www.rtems.org/mailman/listinfo/rtems-users
> regards
> Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130301/bfb66c68/attachment.html>
